Is a trans cooler necessary with TC 3500 stall.
Is it possible to install the transcooler after the shop puts the TC and Flexplatein? Because I kind of already ordered the TC and flexplate already. I have the appointment next week. Someone told me I can hold off and do the transcooler install my self because it is easy.
Originally Posted by SmokingWS6
IMOP, trans temps can get to high on a stock converter, i've ran one with my stock and aftermarket converter. Its 50 bucks that could save you a few grand.
I know a few guys that arent running coolers and they have BIG stalls.. But, they don't drive them on the street every day either. So, in my opinion I'd go ahead and spend the $50 bucks and be done with it. Cheap Insurance!
My tranny cooler should be here soon. I can put it in the car now, correct? (on the stock converter)
As for your question: YES YES YES. Emphasis cannot be put more on it. If you're running a bigger converter than stock, a tranny cooler is a must. I believe the biggest one you can get is B&M's 24,000 and it is only about $55. If you can afford the converter, you may as well put a little extra into protection for it and your tranny.
YES! hell put a scan tool to your car it will scare you the temps you can easily achive with that stall.. the bigger cooler the better and even then im having to do a manual fan switch ((and mabye more tranny cooling mods ie. pan))
BTW, its nearly impossible to over cool a transmission...
Originally Posted by MetallicBluews6
Just ordered a TCI SSF 3500 stall and TCI flexplate is it necessary to get a B&M transcooler?
Let me know guys.
Thank you
Let me know guys.
Thank you
