Help with this mod!
Help with this mod!
In an attempt to increase shift firmness i am going to increase the line pressure by following the link below.I cannot figure out how the connector comes off the solenoid.I have the car jacked up so space is limited and i am not very familiar with an A4 anyway.Thanks for any help!
http://www.ls1camaro.net/sections.ph...ticle&artid=27
Its held on by a clip (I think its called an E clip???) If you're under the car, on your back, looking up at the solenoids...then you will be staring directly at the back side of the clip. Use the flat blade of a screwdriver, or needlenose pliers, to pry and pull it out.
