Northwest Members WA, OR, ID, MT, WY, SD, ND
Anyone wanna take a look at my HP log file???
Old 07-10-2005, 11:51 PM
93TAWicked1's Avatar
Default Anyone wanna take a look at my HP log file???
Mark? Eric? Ellis? Bill?? Anyone??? I have an idea what I'm looking at but not enough to really dig into it. I need a new battery for my laptop it was a short run!!
Old 07-11-2005, 12:17 AM
ram-it's Avatar
Mark, Ellis and Bill are way past my abilities. I am about 1year removed from even playing with HPT but I am looking at getting it again for some future things coming.
Old 07-11-2005, 12:28 AM
So I take that as a no
Old 07-11-2005, 12:35 AM
ram-it's Avatar
I can look at it but I will not pick up on some of the things they will. I have no problem directing you to someone better than I.
Old 07-11-2005, 08:28 AM
Racehead's Avatar
e-mail it to me, I'll take a gander at it and see what I think
Old 07-11-2005, 10:58 AM
narcszm's Avatar
post it here.
Old 07-11-2005, 01:17 PM
I don't know how to post a file here? I can't get a file to be available on my website either...
Old 07-11-2005, 01:21 PM
WAHUSKER's Avatar
If you still need help you can email it to me & I will take a look Bobby. Sorry, in all the hubub over the weekend I missed this. Be sure to tell me what you think you want to do....
GRIFML2@VERIZON.NET
Old 07-11-2005, 02:55 PM
narcszm's Avatar
zip it up (or don't) and click reply to the thread. Down below is a "manage attachments" button which lets you attach files up to 100k or so. make sure it likes the extesion, that's all.
Old 07-11-2005, 10:18 PM
Racehead's Avatar
Well Bobby, Some things DO jump out at me about your tune. For one thing as a good starting point you need to add about 8 to every single cell in your VE table. Your base tune is so lean that it's adding alot of fuel to compensate. You want those numbers in your histogram slightly negative. Adding 8 won't make it perfect, it'll just put you in a much better starting place Also your timing tables need some serious tweaking. There are HUGE steps in between cells. Especially in the lower 20% of throttle. Kind of hard to explain exactly what to do. Can you send me your tune file and I'll just do it ?
Old 07-12-2005, 08:06 AM
WAHUSKER's Avatar
So Bobby, Bills is saying the basic goals are:
You want the fuel trims 0 to slightly neg (-3) until you go WOT, and you want the VE & Spark tables smooth, so your PCM doesn't have to make major adjustments as it transistions from one cell to the next. After you get that done, you should have some more power, & something you can tweak & make progress with. Good job Bill.
Old 07-12-2005, 11:35 AM
Thanks guys! I sent the tune file to Bill to look at!!
Old 07-29-2005, 02:54 AM
OK I just changed the VE table am looking at the spark advance table. Now if I smooth will that help it or are the cells too far apart? Should I add some to a group of lower RPM cells? I'd like to get that sorted then do a longer log tomorrow, maybe with some more WOT logs. Looks like my injectors are just a bit over 80% too. Hope I don't sound too stupid I'm pretty new to this stuff....
Old 07-29-2005, 08:30 AM
TwoFast4Lv's Avatar
BTW I would like to take a look to
Old 07-29-2005, 12:21 PM
Ask and ye shall receive I just sent you the files I have including the stock Z06 bin. I just got done with Bills suggestion on the VE and spark and am going to go for a little ride
Old 07-29-2005, 05:59 PM
Loves to change spark plugs
97BlackT\A's Avatar
And it went....?
Old 07-30-2005, 01:54 AM
Robert56's Avatar
If ya want/need I can look at it also. I have some pretty good stuff going concerning the Z06 and HP Tuner.
Robert
Quick Reply: Anyone wanna take a look at my HP log file???
