??How much fluid for 9"??
Old 07-11-2005, 08:34 AM
1CAMWNDR's Avatar
Default ??How much fluid for 9"??
I am thinking of going with 90W dino oil for the break-in, but how much fluid do I use? Might switch to 80W synthetic after 500 mile break in.
Old 07-11-2005, 10:13 AM
SStillSSmokin's Avatar
I think mine took just about 3 qts. till it was running out the hole.
Old 07-11-2005, 11:19 AM
1CAMWNDR's Avatar
OK. Thanks .
Old 07-11-2005, 01:29 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Originally Posted by 1CAMWNDR
OK. Thanks .
Try to use a quality oil, Kendal or Wolf's Head, are usually what I recomend.
Old 07-11-2005, 02:45 PM
CTSmechanic's Avatar
Also try not to over fill it or you'll get a vent problem... if its running out its a litle too full..
Old 07-11-2005, 05:38 PM
Tally TransAm's Avatar
mine has the optional fill plug. i put 4 quarts in and still couldnt feel it on my finger before i said ok thats enough
Old 07-11-2005, 06:15 PM
1CAMWNDR's Avatar
Thanks guys. I will see about locating some Kendal gear oil in the next couple weeks.
Ryan, do you know of anyone in Tallahassee that has a stock to 1350 conversion U-joint? None of the NAPA stores had a clue what I was talking about.
Old 07-11-2005, 10:02 PM
ChevyGoldfinger's Avatar
What kind of Diff are you running? I would really like to use synthetic in my 9" Moser with the Detroit Locker, but I think they advise against it. Sure would make it run cooler. Anyone know if all the mfgs. still insist on Dino gear oil for the Detroit Locker?
Old 07-11-2005, 11:40 PM
LS1Tech Sponsor
After break-in I wouldn't worry about changing over to synthetic.
Old 07-11-2005, 11:58 PM
Really? What would you suggest for a 9" with a full on Detroit Locker? (not a "soft locker")
Would you go with:
Amsoil, Redline, Royal Purple, or other?
Which weight? (I live in the desert where 170* track temps are not uncommon in the summertime)
SAE 75W-90 Synthetic Gear Lube
SAE 80W-90 Synthetic Gear Lube
SAE 85W-140 Synthetic Gear Lube
Thanks for any suggestions.
Old 07-12-2005, 10:23 AM
JRracing's Avatar
The stock to 1350 U joint, you can pick up at AUTO ZONE I hear. Thats very common.
Old 07-12-2005, 11:42 AM
A Detroit locker is not a friction type differental the type of oil you use shouldnt matter, I run nothing but mobil one 75-90 for drag racing a oil with a thicker film strength isnt a bad idea i.e 80-140 I have seen some of the Red Line "shock proof" used with sucess
Old 07-12-2005, 01:20 PM
Hey Harley! How's it going?
I guess the best thing to do is give Dan a call and see what he recommends these days. The 9" was installed at Adam's but last time I was there that kid seemed clueless. I guess Rusty left for Montana or somewhere.
They put dino 80 w 140 in it when Rusty was there a couple of years ago. Not sure what others are using, but it makes sense to me to use the synthetic if it won't do any harm. The benefits in this heat are obvious. Also, there might not be as much parasitic power loss with the syn.
What do you guys use in those race trucks?
Old 07-12-2005, 02:38 PM
Hey John... We run 75 90 or 85-140 Mobil One... just depends on the track..
Old 07-12-2005, 05:26 PM
na all the napa guys here are retards
if you dont have a part number they have no idea what you are talking about
Old 07-12-2005, 10:02 PM
1CAMWNDR's Avatar
I will check with some of the Autozone stores around here. I am going to have a 31 spline Detroit Locker and will use 80W 90 Dino oil for the breakin and then might switch to a 80W 90 Synthetic.
Old 07-14-2005, 10:14 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I run regular 85/140 and my 9" takes less than two full quarts. I fill it till it dribbles out the side fill.
Old 07-14-2005, 10:25 PM
Hey John, that's what the shop that installed mine put in it as well. I wonder if the high quality synthetic gear oil would harm these 9"/Detroit Locker diifs? Have you ever asked around about it?
BTW. . . congrats on the new time man! Great job for the first time out. It'll probably go better when it cools down this fall.
Old 11-16-2005, 10:21 PM
Mr_president's Avatar
i ran redline synthetic and 3 months later blew the pinion bearings , might now be the cause but might have been!?!
