??How much fluid for 9"??
Ryan, do you know of anyone in Tallahassee that has a stock to 1350 conversion U-joint? None of the NAPA stores had a clue what I was talking about
Would you go with:
Amsoil, Redline, Royal Purple, or other?
Which weight? (I live in the desert where 170* track temps are not uncommon in the summertime)
SAE 75W-90 Synthetic Gear Lube
SAE 80W-90 Synthetic Gear Lube
SAE 85W-140 Synthetic Gear Lube
Thanks for any suggestions.
I guess the best thing to do is give Dan a call and see what he recommends these days. The 9" was installed at Adam's but last time I was there that kid seemed clueless. I guess Rusty left for Montana or somewhere.
They put dino 80 w 140 in it when Rusty was there a couple of years ago. Not sure what others are using, but it makes sense to me to use the synthetic if it won't do any harm. The benefits in this heat are obvious. Also, there might not be as much parasitic power loss with the syn.
What do you guys use in those race trucks?
if you dont have a part number they have no idea what you are talking about
I will check with some of the Autozone stores around here. I am going to have a 31 spline Detroit Locker and will use 80W 90 Dino oil for the breakin and then might switch to a 80W 90 Synthetic.
BTW. . . congrats on the new time man! Great job for the first time out. It'll probably go better when it cools down this fall.
