Oil pressure after rebuild...
Old 07-11-2005, 08:15 PM
digitalsolo's Avatar
Default Oil pressure after rebuild...
Okay, just got my rebuild fired up, and minus a slight oil leak (I need a new rear oil pan bolt, I ran mine over with a hoist, so I'm short one) everything seems great. I filled the cooling system (which seemed to go very well) and it sits right at 190* after warming up. I don't have a radiator fan on it, so I didn't run it very long, about 5-6 minutes, a couple of 1/2 throttle runs.
My oil pressure at idle after warm up is about 42-43 psi, and it went up to 65 psi at 1/2 throttle. This seems pretty good to me, but this is my first LS1, and first complete rebuild, so I'm perpetually parnoid.
Also, any bad sounds I should be listening for? I hear no ticking or knocking, but, I'm still new at this rebuild stuff.
Thanks guys!
-Blake
edit: Oh, I did run it at idle, with a few blips now and then for about 20 minutes on the very first start.
Old 07-11-2005, 08:28 PM
ss rally red's Avatar
If hot idle is 40+ and 2500 rpm + is 60 psi of better you are good to go.
Old 07-11-2005, 08:31 PM
Good stuff. Now I just need to get some exhaust on it, and fix that oil leak, and then I can get some real street testing done.
Old 07-21-2005, 01:43 PM
Well, just as an update, after a little more break-in, I seem to sit at about 33 PSI or so on a hot idle (780 RPM, give or take) and it still runs up to about 65-70 as I get over 4500 RPM, so I think I'm good as far as that goes. My oil pan (or my re-reinstalled rear main) is still leaking like a damn sieve though , so I'm pulling it out AGAIN tonight to recheck everything. I think it must be my oilpan-rear cover point, as I KNOW I put the rear main in dead-nuts on. We'll see tonight.
Old 11-26-2007, 11:30 PM
Someone asked me about this today, so I figured I'd post up what the problem was.
Warped oil pan. WTF is up with that?
My oil pressure was fine, bad gauge was giving me inconsistent readings.
Old 11-27-2007, 12:11 AM
stevied916's Avatar
how did you fix the gauge?
Old 11-27-2007, 07:00 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Agreed
Old 11-27-2007, 07:51 AM
Garbage can.
Old 11-27-2007, 10:00 AM
JPH
JPH's Avatar
i say your fine blake, the way things are going for you.
Old 11-27-2007, 10:08 AM
1320 killer's Avatar
the minimum oil psi needed in an ls1 is 6 psi per 1000 rpm. it seems like your pressure is fine. good luck
Old 11-27-2007, 10:37 AM
Heh, just FYI. I was just updating this thread for informational purposes. (If you notice, it was 2 years old...)
I don't even have this engine anymore. I've had another 5.7L, a 6.0L and a 5.3L in it since then. I'm currently putting together a forged 370" motor with an L92 top end for big spray.
I am building another RX7 with the engine from this thread (new oil pan) and a T56 in it this spring. Won't be the "fast" car though.
Another random bit. After my old (ebay purchased) gauge died, I bought a shiny new one from JPH here, and it works like a charm.
