nx wet kit nossle installation
Old 07-16-2005, 08:45 PM
half-n-half's Avatar
Default nx wet kit nossle installation
hey guys i have recently purchased an NX wet kit and i am awaiting for it to arrive. now it does not come with the instructions. is there anywhere to get them to aid me through the install?
Also how am i going to get the nozzle into the intake tract after the maf. i dont really need pictures i just saw them, but parts needed and a little how-to would be awesome.
Thanks
Louie
Old 07-16-2005, 08:54 PM
tbsimmons's Avatar
I drilled and tapped the MAF end. Works great if you have a Ram Air, which I assume you do.
I know your car is not a LT1, but same idea.
Old 07-17-2005, 01:28 AM
i like the idea. would it really be that easy? where can i drill and tap the maf end at?
any other ideas/input?
Also anything on the install instructions?
thanks
Old 07-17-2005, 03:03 AM
JustAnIlluzion's Avatar
u can get a aftermarket bellow, like slp or a fernco from home depot, they are thick rubber and u can drill a hole in it and put in the shark nozzle tighten the nut and be done. if u want it cleaner, get the maf plate from nitrous dave or get a TB n2o plate.
Old 07-17-2005, 03:09 AM
JJ1965's Avatar
I used the SLP smooth bellow, and put the nozzles in it, worked great.
Old 07-17-2005, 07:39 AM
tbsimmons's Avatar
I just took the MAF ends off and drilled and tapped the one close to the engine at the center.
I had mine in a bellow, but I kept having problems with the nozzle not sitting straight after a while, it would hit one of the throttle blades more on one side. The drill and tap works great. Nice and tight.
Old 07-17-2005, 09:01 AM
ok, thanks guys.
i have a couple of questions now so i can go ahead and install this whichever way i think is best.
first off how do you guys get the nozzle to stay in the smooth bellows? drill a hole, and then stick it in...?
troy do you happen to know what size tap is needed?
Thanks
Louie
Old 07-17-2005, 09:47 AM
XTrooper's Avatar
All NX installation instructions can be found on this page in pdf form.
http://www.nitrousexpress.com/Instructions/main.htm
Old 07-17-2005, 06:37 PM
awesome. thanks.
Old 07-18-2005, 05:33 AM
XTrooper's Avatar
Originally Posted by half-n-half
awesome. thanks.
You're welcome!
Old 07-18-2005, 10:04 AM
NXJeremy's Avatar
XTrooper beat me too it, lol. All the instructions are on that link with pics and tuning tips as well. As far as holding the nozzle in the bellow, there is a two-piece nut the will thread together in the hole you drill in the bellow. This is what holds the nozzle securely in bellow. Drilling and tapping a hole in the MAF end isn't a bad idea either.
Old 07-18-2005, 09:33 PM
all right, cool. Thanks
Louie
Thanks for the help fellas. kit should be here tomorrow...
