What kind of Race Gas do you use???
Restricted User
If you use race gas, or mix, please post up what one. I am also wanting to know if anyones used this from VP Fuels:
NO2
Recommended for fogger or three-stage nitrous oxide applications with CRs up to 18:1. Higher octane and lower specific gravity than most nitrous fuels. May require enriching fuel mixture more than would be required for C16.
• Color: Clear
• Motor Octane: 120.3
• Specific Gravity: .699 at 60° F
Yep, its leaded, and in controlled quantities I havent had an issue using leaded racing gas mixed with pump.
Thanks.
Charlie
NO2
• Color: Clear
Thanks.
Charlie
Originally Posted by ty_ty13
does any of this hurt your sensors?
I don't suggest using leaded fuel unless the car is strickly for the track, or if you are using oxygen sensors specifically designed to resist lead.
That was a $120 mistake.
For unleaded application, try TOrco Accelerator...its a race gas concentrate and I have used this successfully with 200 shot on 93 octane with 1/2 tank of gas and one bottle of Torco.
SDB
SDB
NO2
• Color: Clear
Thanks.
Charlie
NO2
• Color: Clear
Thanks.
Charlie
Restricted User
Interesting, I didnt think there would be that much deviation. I run WTFE is available, leaded or not. But, bored looking around racing fuel sites and other drag tech section I seen mentions of Nitrous blends and sparked my curiousity.
I have seen TORCO, but leary to use it, I thought about using three of the 1pt cans (think its one pint, maybe quart), I dont trust something based off a label. Glad to hear it works for you SDB. So you use one small can mixed with pump at half tank? I normally race at 1/4 tank, would adding one can to that hurt me any or no?
Pink eyes Lets just say its from the race gas ok!
Restricted User
Damn....being stuck on the island I feel so sheltered from all these different fuel alternatives. Liking the Torco Accelerator, and better yet there are several places that carry the stuff on island.
What is powermist?
LOnSLO, yeah I would definately mix it. I normally mix with pump unless I only run 100 octane then I go straight.
What is powermist?
8 second mod
how would open loop do on a friday and sunday night driver?
