TSP Dual owners, ever cut off your turndowns?
I was just wondering if there was a way to lessen the drone at highway speeds. I think that if the sound waves weren't facing towards the ground, then it wouldn't be so much of a problem. I'm planning on going to Sweet Thunders in the future, but don't have the spare cash for them right this second. I do however, have a jack, some jackstands, and a Sawsall.
Anybody done this? If so, what were the results?
I don't know if cutting off your turndowns will give you the result you desire. The turndowns usually lessen noise. Do your true duals have a crossover at the midpipe?
Sold The Fun Stuff :(
You aren't going to burn anything. There is plenty of atmosphere for the heat to dissipate before getting near anything else.
I have long tubes, no cats, x-pipe, and Moroso Spiral Flow mufflers. I originally had turndowns on it, then I cut them off. With the turndowns you get a little more "thump" and without them you get a little more "chop" if that makes sense. Seems like the turndowns have a little bit more of a bassier exhaust note while with them cut off they are a slightly higher pitched. The jury is hung. Half my buddies say the car sounded better w/ the turndowns, half say it sounds better without them.
Inside the car cutting the turndowns off took away some of the rattles and resonance, but it was slightly more audible. It's basically give and take. Do you want a deeper exhaust note with a little more rattling inside, or do you want a little more volume inside but not so much rattling and resonance?
I'd like to hear from some guys with Sweet Thunders as well, to see if they added turndowns. My idea when I do the swap was just to cut the Bullets off the hanger, then slip the ST's on, clamp 'em, and re-weld the hanger to the muffler, and not worry about a turndown.
Well, ST guys, did you add turndowns?
Personlly ive got dumps before the rear...some might not be as bright...
A friend of mine cut the pipes off the rear to add new mufflers, and never welded on turndowns....sounded badass....Only problem was that when he discovered his new found mess of black darkness over the rear and torquebox, he spent his saturday morning cleaning it up and welding a set of bends...
add the turndowns, youll be happy you did.
Suck it up, Allen
I think your best bet is to go to Child's and talk with them about about going over the axle. If you do go, tell them that if they give you a good price, they will have another customer as well. Should help you out a little.
Unless someone makes the pipes ready to go?
Originally Posted by Orange n Black
Suck it up, Allen
I'd be better off buying a good welder and doing it myself if I were going to take it out the back.
When I originally installed my TSP TD's and the turndowns were pointed straight down, I had a great deal of vibration inside the car, which really began to annoy me after awhile. So I had pipes run out the back, but that made the the exhaust sound very harsh and it lost all of the deep rumble. So I cut the pipes off, but I did it in such a way that the exits are angled out towards the outside of the car and not straight down. That took care of about 90% of my interior vibration problems, and kept most of the deep rumble caused by the exhaust echoing around under the car. If I was to do it all over, I would cut the turndowns off, and then weld them back on at about a 45* angle towards the outside of the car.
