Guys with fairly large cams, does your engine shake?
I know all engines shake but when you cammed your car did it seem to shake a good amount afterwards? Can you actually sit and watch your engine shimmy back and forth with it running or is it pretty smooth?
I've had two cams with larger durations(a lunati, and a Fm13) and they shake pretty bad even after tuning. I am going to swap back to my lpe cam. It made more power with a better torque curve. Also, It runs smooth as silk.
its what happens when reversion increases. thats actually slight misfiring and one one the main reasons(in my opinion)the bigger cams cant get a CARB EO number. its the same thing that causes the lope we listen for/hear to hint us that the engine isn't all stock like the owner says.
