back firing?
Old 07-18-2005, 07:47 PM
AnthonyConstant's Avatar
Default back firing?
when i spray...it back fires....i do have my muffler cut off though....at about the 4500 rpm and up back fires...whats this mean
Old 07-18-2005, 10:44 PM
Robert56's Avatar
Is this by any chance a wet kit?
Old 07-19-2005, 04:11 PM
No sir its the dry kit that we talked about, about a month ago.
Old 07-19-2005, 04:47 PM
cantdrv65's Avatar
Talking
Old 07-19-2005, 04:48 PM
cantdrv65's Avatar
Post
Check your A/F ratio....What does your fuel pressure look like? You are running lean and or have an ignition problem...Have you taken a look at the plugs?
Old 07-19-2005, 04:54 PM
Nitro Dave's Nitrous Outlet's Avatar
LOL...
Robert I know where you were going with this and it backfired.
Im sorry I could not help myself.
Dave
Old 07-19-2005, 04:55 PM
Anthony,
Does it pop through the exhaust when you shift? Or is it poping through the intake.
Dave
Old 07-19-2005, 05:26 PM
Robert56's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
LOL...
Dave
Yep, Dave, busted.
Anthony, sorry, I reconize the name but don't remember what we talked about or the issue. Refresh my memory if it pertains to this question.
Robert
Old 07-20-2005, 10:56 PM
Yep, Dave, busted.
Robert
Na, Robert.
It was that i had bought an incomplete LS1 kit off of here and traded a guy on here for his incomplete Lt1 kit. to put on my lt1.
hahaha
Old 07-20-2005, 10:57 PM
Anthony,
Dave
Through the exhaust, i have the stock fuel pump....2 months old ac delco. and stock plugs about 6 months old.
But i have NO muffler.
LOL...
Dave
Old 07-21-2005, 08:55 AM
cantdrv65's Avatar
Post
Have you checked A/F ratio yet? What do your O2s read while WOT and spraying??? They arent the most accurate way to tune but you can definitely see rich and lean....
Old 07-21-2005, 09:11 AM
Ok the stock plugs are more than likely the problem.Change your plugs to NGK TR6s and then tell me what happens.This should fix the problem.
Dave
Old 07-21-2005, 10:15 AM
NXJeremy's Avatar
popping through the exhaust is generally a rich condition, or ignition issue (like Dave said, change the plugs).
Robert, you crack me up
Old 07-21-2005, 01:18 PM
white2001s10's Avatar
Too rich,
try moving the nozzle further from the MAF, and swap to a colder plug like an AR472
