Ok here it is, my hood purge pics
Old 07-21-2005, 06:44 PM
Kens98TransAm's Avatar
Default Ok here it is, my hood purge pics
Purging from the hood....
http://memimage.cardomain.net/member...8_624_full.jpg
http://memimage.cardomain.net/member...8_625_full.jpg
Old 07-21-2005, 06:47 PM
rg42284's Avatar
sweet!!!
what purge kit is that?
Old 07-21-2005, 06:51 PM
MetallicaMatt's Avatar
sweet, i hope mine turns out like that one
Old 07-21-2005, 07:07 PM
Its an NOS...its a dual purge....i got it off of ebay for 90 dollars....its a good deal and works great
Old 07-21-2005, 07:25 PM
ROCNDAV's Avatar
looks like a dragon breathing out ofits nostrils!!! like this:
anarchy99's Avatar
where is your purge mounted? I've also got the nitrous purge kit, but mine doesn't have enough line to reach all the way to the nostrils on the hood.
Old 07-21-2005, 07:29 PM
Airwolf's Avatar
What he said!!!!!!!!!!!!!!
Old 07-21-2005, 07:36 PM
JustAnIlluzion's Avatar
buy more line.. u can use brake line.. trans line.. both are easy to bend and strong and most come with flared ends with nuts that have the correct threads that fit in a purge solenoid. stay away from rubber/silicone hose, i have had some crack and break apart.
btw sweet pics
Old 07-21-2005, 07:40 PM
nostyta's Avatar
Nice setup and sweet lookin ride.
Old 07-21-2005, 07:51 PM
anarchy99's Avatar
thanks for the help justanilluzion.
Old 07-21-2005, 08:31 PM
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA Thanks for all of your comments, here are some pics of the purge setup in case you are wondering how I got it all to reach the hood.
http://memimage.cardomain.net/member...8_618_full.jpg (the purge solenoid)
http://memimage.cardomain.net/member...8_619_full.jpg (hose going up the hood)
http://memimage.cardomain.net/member...8_620_full.jpg (hose on the hood held by clamps)
http://memimage.cardomain.net/member...8_621_full.jpg (hose going through holes drilled in the baffles)
http://memimage.cardomain.net/member...8_617_full.jpg
(close up of ram air hood)
HOPE THIS HELPS YOU GUYS OUT, I REMEMBER DOING SEARCHES FOR PICS AND HAD PROBLEMS....LET ME KNOW IF YOU NEED MORE PICS, IM WILLING TO HELP OUT
Old 07-21-2005, 08:57 PM
anarchy99's Avatar
What kind of hose is that? any worry of it blowing off or failing?
Old 07-21-2005, 09:08 PM
Its a 1/4 inch refrigerator water supply line(plastic)....its very secure....the sticky clamps hold it in very well....the lines folds up with the hood when it closes so it doesnt get stuck on anything......and no damage has occured to the hose due to heat from the engine....you can get the line from a home depot or hardware store.
Old 07-21-2005, 09:14 PM
gollum's Avatar
Some things are better left unsaid.
