SLP Lid is on......
Old 07-26-2005, 01:27 PM
2000 TAWS6's Avatar
Default SLP Lid is on......
Since I had the whole deal out of the way to put in my water pump, I put on an SLP lid too. Having an 00', it came with everythong I needed to hook up to stock air (?).
Toughest thing was getting the IAT sensor out of the factory lid.
It sounds different and feels like it makes more power faster.
$ 100 well spent
Old 07-26-2005, 01:47 PM
2001NBMZ28's Avatar
A few drops of liquid dishwashing soap helps with the IAT sensor/grommet - rinse and dry thoroughly before reinstalling. I know, too late now.
Old 07-26-2005, 02:39 PM
2000LS1Z28's Avatar
I agree, the intake lids are a great bang for the buck. You should notice a little more air sucking sound under the hood, but I doubt you'll feel 10 extra rwhp on a car already making close to 300 stock...
I couldn't feel a difference when I put the Direct-Flo's on either of my LS1's...
Mike
Old 07-26-2005, 05:58 PM
mrr23's Avatar
stock vs SLP airlid with paper filter on my car. leaned it out a bit.
Old 07-26-2005, 07:11 PM
HFLDtA's Avatar
hfhfgsfg
Old 07-26-2005, 07:39 PM
Mat
Mat's Avatar
Definately don't go cutting things!
It'll come out if you undo the two clamps fore and aft the MAF sensor itself. Just be patient and keep working at it as mine was VERY tight on the stock stuff and it was a bit of a pain to get it off the first time. It'll come.
Good luck man.
Old 07-26-2005, 08:29 PM
2000 TAWS6's Avatar
Originally Posted by HFLDtA
How did you remove the MAF sensor from the airbox? I am about to purchase a lid but cant figure out how to get it out. Should i cut the it out?
Take a small flat blade screw driver and pry the sides off one at a time. Work around each corner a little at a time and both sides will pop right off.
Pry between the rubber/plastic and the metal case of the MAF.
Old 07-26-2005, 11:43 PM
REDWS6ROCKET's Avatar
a lid is a big bang for the buck. i thought i had a different car after a lid and had a cut out installed. like stated the maf sensor is very snug fit just work it a little at a time don't cut anything.
Old 07-27-2005, 09:48 PM
98SuperSport's Avatar
you can see it though if you watch before and after you put it on....i felt it and saw it, but i did the two runs withing 30 minutes of each other
Old 07-28-2005, 12:12 AM
HFLDtA's Avatar
Awesome. Thanks for the info.
