mounting pics of satellite recievers
anybody have pics of how you mounted your plug and play unit? i just got a sirius reciever but have no clue of where to mount it. all i know is im not using the gay suction cup window mount they provide. any ideas/pics would be appriciated. thanks
10 Second Sleeper Club
I just recently mounted a sirius plug and play in my Z a few weeks ago. Couldnt stand the freekin mount so i did some thinking on it for a few days. This is what I came up with-"Velcro", yeah thats right, Velcro. I cut a small piece of Velcro and mounted the antenae to the top of my rearview mirror. Inside car antenae equals no car wash or theft worries and good reception due to location. I then ran the wires for the antenea under the headliner toward the drivers side of the Vehicle. Ran the wire down the side of the car through the weatherstriping then rerouted it under the dash and through the back of the center console and in between the centerconsole and where the dash unit ends. Lots of nice space to run wire out of sight. Next I routed the power cable under the center console and ran the wire toward the back and routed it back toward the front in between the console and dash (are we confused yet?). you can cut 2 small squares of Velco and run the wires through them and secure them in between the dash and console so your wires will stay in place.
I used the space next to the cigarette lighter where the stroage compartment is for stuff like cigs and other stuff. I cut two strips of velcro and put them on the sides of this compartment-NOT ON TOP OR BOTTOM as this may interfere with the air venting of your unit or the ability to use your mount because it will cover the two slots used for the mount. Let the tape sit for 12 hours without jacking with it so the adhesive will set strong.
I then took a visual on where the unit would look centererd, removed the tape backing and pressed it onto the exposed adhesive of the velcro. Once this is done don't mess with it for another 12 hours and low and behold you will have a really decent center mount without that monstosity of an arm staring you in the face. I did this also because I have a home setup in which I move my unit from car to house and can do this without any problems. I have not figured out how to upload pictures on to this site yet but if you E-Mail me at jitsumania@yahoo.com I have pictures of the sequence that I can send you so these instructions will make more sense. "A picture is worth a thousand words". Take care, hope this helps. It did me!!!!
Copy & Paste Moderator
https://ls1tech.com/forums/wiring-stereo-electronics/248790-guys-xm.html
(post #3 & 9)
Well heres XM set up. antenna is on rear veiw mirror inside the car and since regular radio SSSS U C K S i mounted the dock right on the screen of the stock radio. Dock swivals so I can play CD's if I want BUT hell with all that I LOVE MY XM.....THE HOME OF OPIE AND ANTHONY.
Spread The Virus
Spread The Virus
mount part 2 (VELCRO)
here are the rest of the Pics for the mount on the console. Did learn how to upload the pics. but could only do 5 ata time. This is a good mounting solution cause the passenger also has access to unit.
Maroon Z-28 2000 AT , SLP flow pac cold air, SLP free flow lid, K&N filter, SLP high flow MAF sensor, SLP smooth Bellows, MSD 8.5 superconductor wires, Magnaflow Catback, Jet performance programming stage 2, Kuhmo rubber
Originally Posted by co.6z28
thanks for the pics guys. i will try the way badss mounted it. i cant do it like the one above b/c the shifter is in the way(m6). i wouldnt have enough room
Good luck Bro
Ungrounded Moderator
I don't have any pictures but what I did was get one of those plastic swivel mount things for cellular phones (kind of like a CB microphone hook) and mounted it to the outside edge of the radio surround trim panel. My Sirius StarMate has the button already on the back so it just hangs in place next to the radio although it blocks some of the right side of the radio face. The advantage is that I can just lift it out of the way if I want to use the radio controls and it doubles as a microphone hook for my CB radio.
You know the way you guys mounted yours is cool and all, but my setup beats it all. Ever thought of using your center console?? I have my Sirius mounted inside the console so when you want to change stations you open the console and voila. Its out of site, so less obvious, the antenna is mounted on the inside of the car. Just by looking at the car you'd never be able to tell I have satellite radio. I have pics, just dont know how to post them on the forum.
Here is how I mounted my Sportster sirius unit:
It's out of the way from the shifter, yet close enough to reach to switch channels/presets. If anyone hasn't tried it yet, get the sirius fm module relay (http://www.circuitcity.com/ssm/SIRIU...ductDetail.do). I was sick of listening to high quality stations through the FM modulator built into the unit that sounded like **** through the stock monsoon stereo. It's now 100% better, as if the sirius unit is hooked directly into the headunit via rca or cd changer port. Any questions on my install feel free to ask, installation was a piece of cake.
I used a GM9-AUX to convert the Monsoon CD-Changer port to RCA AUX-IN.
Check this out for more info:
https://ls1tech.com/forums/showpost....15&postcount=3
https://ls1tech.com/forums/showthrea...hlight=gm9-aux
Does your Sirius unit have RCA or 1/8" outpout?
If not, then you need to buy the appropriate adapter to get RCA output from the Sirius unit.
I made a small video of how to remove the bezel and put it back on:
http://users.rcn.com/my57chevy/RadioBezel.wmv
To retain the factory CD-Changer and the new RCA AUX-IN, you need a 2001+ Monsoon headunit. Press "CD/Play" on the Monsoon headunit to cycle through the inputs.
It's a metal bracket made by Pro Fit.
My Sirius unit has a 1/8" output, thought about doing what you did and using an adapter for the cd changer port but wanted to give the relay module a try first. It's actually a 1000% better quality than the built in fm modulater, but not as high quality if I had xm/sirius headunit & add-on unit that uses a s-video type connecter.
what did u use to munt that?
where did u get the stuff to mount it, i got the starmate also.
Here's a picture (the dash mount is the part on the right).
