Timing ?? On Spray
Old 08-09-2005, 04:22 PM
BLACKBIRD8200's Avatar
Default Timing ?? On Spray
My question is my i got a mail order tune from ls1 speed and told them that i ran a (75hp) shot of nitruos (wet). long tubes 0ff road y-pipe, 3:42 gears.
and they set the timming to 25* at wot will this be fine on a (75hp) shot or do you think the timing is to low? would it be fine for a (100hp) shot?
i'm just a little worried. i do have a rpm window switch set to come on at 3000 and off at 5800
the kit is a zex wet kit thanks for the help
Old 08-09-2005, 04:57 PM
GM Muscle's Avatar
You should be fine, that's pretty conservative. You should easily be able to bump it up to a 125 shot with that timing if you run 93 octane.
Old 08-09-2005, 08:31 PM
Thanks for the help!!
i'm curious do you know what kind of times i'd be running with a (100hp) shot
my times are 13.20 at 107 (no spray)
Old 08-09-2005, 08:39 PM
GM Muscle's Avatar
There are alot of factors and I'm not sure if Zex rates at the wheel or motor (more than likley the motor). You should see low 12s at over a 115mph pretty easily. I wouldn't be suprised if you dipped into the 11s.
Old 08-09-2005, 08:43 PM
thanks alot i guess i'll find out this weekend
Old 08-09-2005, 08:56 PM
2 Stroke Racer's Avatar
How many degrees should I retard for A 150 wet shot???
Old 08-09-2005, 09:32 PM
Loudmouth LS1's Avatar
****, 25 degrees is pretty conservative!! On my stock motor with a cam and stock heads (stock compression) on 93 octane I was running the stock 28 degrees of timing on a tnt 100 shot!
And right now with my 374 cube motor with almost 11.5:1 compression on 93 octane with a 100 shot I was running 24 - 25 degrees of timing, I just downed it to 22 degrees for the 150 and i'm thinkin i'll probably leave it there for the 200, just gotta talk with a few buddies and make sure that that's ok.
Old 08-10-2005, 12:41 AM
LoWeLL216's Avatar
The Zex power ratings are at the motor not rear wheel.
Old 08-14-2005, 11:39 AM
Well the best i could get was a 12.70 at 114 mph 60 foot was 2.00
maybe i'll do better next time? on a good note i did manage to cut a perfect light triple doughnuts .000
Old 08-14-2005, 11:47 AM
brad8266's Avatar
I run 150 on a stock tune, no detination at all.
Old 08-14-2005, 05:09 PM
SSTYCOON's Avatar
Any way to retard the timing without ls1edit, hptuners etc.......
I'm thinking about a 100 shot or so, or is it not even nesscessary to retard it?
On the dyno my air fuel was arounf 13.0-13.1 with cam and bolt ons, stock tune
I 'd be using a wet kit
Old 08-14-2005, 10:38 PM
NXZ28's Avatar
You got the mph to run a low 12, maybe even a high 11. Gotta work on that 60'.
Old 08-14-2005, 11:09 PM
gollum's Avatar
This will pull -3 degrees only when nitrous is activated. PM Robert56 for details.
Old 08-16-2005, 10:28 PM
speedz06's Avatar
What about timing with a tntf2 and a magcharger does anyone run this maybe you can give me some direction.I am installing a Timing Tuner with the system as well as alky inj.
Old 08-17-2005, 08:36 AM
hourang's Avatar
get it dynotuned...
