shimmed 918's Max Lift !
Old 08-12-2005, 12:02 PM
disposer's Avatar
Default shimmed 918's Max Lift !
i am thinking of getting the comp 918 springs, i have see some people shimming them for about .050 but i didnt understand why!
my question is what is the Max valve lift that they can hold if they were shimmed to a .050 ?
PS: my shift point will be around 6800-7000 RPM
thanks for the help guys
oh i almost forgot, from where i can get the .050 shims ?
Old 08-12-2005, 12:39 PM
xfactor_pitbulls's Avatar
Not shimming .050, but shimming to within .050 of coil bind. Brian I forget off hand, but isnt the coil bind right around .700? So if you were say running a .620 lift cam you would want to shim about .030.
Brandon
Old 08-12-2005, 12:40 PM
disposer's Avatar
i didnt get the cam yet but i am thinking of getting the G5X3 or G5X4
or some similar cams
i have a 98 camaro ss with a 383 ci, M6 but it will be swaped to a TH400
so the new camshaft is going to be for thew new tranny, thats why i have to choose the camshaft first
the car is going to be mainly for a strip use and little bit of street races
Old 08-12-2005, 01:08 PM
777's Avatar
Any reason you aren't going to go with a nice dual like the 921, prc's, or patriots?
Old 08-12-2005, 03:20 PM
disposer's Avatar
the 918 are beehive so i am going to save some valve train weight, that means more power, thats all
.. well what do you think guys should i go with the 918s or the 921s ??
Old 08-12-2005, 03:29 PM
What cam?
Brandon
Old 08-12-2005, 04:17 PM
AgFormula02's Avatar
A double spring may cost you some power due to added valve train weight, but as long as you use TI retainers, the difference is minimal.
Spend the money and get a true double spring. It is cheap insurance against Mr Piston meeting Mr. Valve.
Old 08-12-2005, 08:42 PM
SideStep's Avatar
Originally Posted by Brian@CompCams
I will have to disagree...the difference is more than "minimal". A steel retainer for a 918 weighs less than dual Ti retainer......let that sink in for bit....
Cool....
Old 08-13-2005, 06:52 AM
PREDATOR-Z's Avatar
918 Tit retainer is at 7gr
My PRC dual tit retainer at 11gr
Old 08-13-2005, 09:15 AM
oange ss's Avatar
did you use the PRC springs or the 918's ?
Old 08-13-2005, 09:38 AM
PREDATOR-Z's Avatar
I ran 918's cam only on 241 stock heads for over 10+K miles; just last week, I installed a set of PRC stage 2.5- 5.3L heads and they came with PRC "platinum" dual springs and an extra retainer lodged in one of the water passages.
So yes, I run PRC's right now.
PRC "Platinum" are good to .670 lifts advertised.
Old 08-13-2005, 10:14 AM
oange ss's Avatar
do you see any reason to run the PRC springs instead of the 918's on a 224/228 .588 cam ? the 918's also have Ti retainers and were used less than 1000 miles, oh and I also have PRC 2.5 heads
Old 08-13-2005, 11:16 AM
PREDATOR-Z's Avatar
If the heads are allready assembled with the PRC springs, then leave them as is and install them. Why bother, there is no real negative effect with a small cam like yours (or mine).
I would put new 850-16 lifters on (Comp Cam) as extra safety.
Old 08-13-2005, 11:24 AM
oange ss's Avatar
i just dont see the point in runnin those big springs with a "small" cam, I also wonder if the 918's will have any problems controlling the heavier valves and of course the added stress on my stock lifters is also a concern, but I see no reason to replace them with only 35,000 miles on the clock
Old 08-14-2005, 07:49 AM
98A4LS1's Avatar
I was wondering the same thing, stiff dual valve springs on a small duration/lift camshaft. Wearing out the cam lobes and lifters quicker?
