Crank and piston question
I'm in the middle of re installing this crank. I just got it turned. It looks pretty good, as i was about to install it i noticed a very small chip about the size of the tip of a lead pencil. Really really small. Should i take it back and have them resurface that or could i install it? If i do install it like it is. Will it just spin another rod bearing?
Also, when installing the pistons. Do they go back in any particulare order. Or could i just put them back in? I didnt notice any numbers on them. On the tops there is that dot on all the pistons, So those dots all point towards the front of the motor. Is there anything else i need to look out for ?
Chip in the crank? Do you mean it was dinged after it was ground? That would need to be polished out. It is OK to have a divot, but not OK to have metal standing tall, even .001 would be bad. Pistons in what hole?? You are putting new rings on aren't you?? It would be best to put them back in the same hole.
No he is not replacing the piston rings. Is that gonna be a problem? The motor is an 02.
It had alittle ding that went into the crank after it was ground.
Here is a pic of what im talking about.
Will this cause a problem (like spin another rod bearing) or could i go ahead and install the crank ?
Also on one of the pics i circled one of the sides. It looks alittle un even. Any input?
I got the crank sent back out to get fixed.. They said there might be a possibility that the crank can break when they try to weld or fix it... But they said that the first time i took it to them. So, not worried about that. But i will be needing new main bearings and rod bearings....
alright.. The hone needs to be done on the heads, correct? Could the hone be done at home. Or will i need to get that sent out also?
Also, why does it need new rings? I see you mentioned blowby, but what causes that? Just because i pulled the pistons outta the heads? The motor has 33k miles. Spun a rod bearing and thats it. I didnt think i needed to replace the rings also.
