Torquing ARP head bolts...
Old 08-17-2005, 05:01 PM
99ssleeper's Avatar
Default Torquing ARP head bolts...
Do you think there is really any difference between the ARP assembly lube and the Permatex assembly lube?
The local speed shop and SDPC (where I just placed an order for some parts today) is out of the ARP lube.
Thoughts?
I dont really want to use the 30 weight oil as mentioned in the ARP directions.
Old 08-17-2005, 05:41 PM
mr2guru's Avatar
Why not?
Old 08-17-2005, 06:22 PM
smask04C5's Avatar
Yes, any good moly assembly lube will provide more accurate torque values than regular oil.
Old 08-17-2005, 06:28 PM
conan's Avatar
I used motor oil when I put mine in with out any problems. I poured a quart into a bucket and diped the entire bolt in.
Old 08-17-2005, 07:21 PM
99ssleeper's Avatar
Originally Posted by mr2guru
Why not?
Given the choice, I'd rather use assembly lube than motor oil...especially if it's conventional motor oil.
I'm wondering if there is really a difference between the assembly lubes....ARP, Permatex, Royal Purple, etc...
How much do I put on the threads??
Old 08-17-2005, 08:04 PM
racecar's Avatar
Just cover the threads. Assembly lube will give you a different torque than oil.
If you can't find assy lube, you can use oil, but you need to torque more.
Use the right torque spec for the lube/oil that you are using.
Old 08-17-2005, 08:33 PM
GMPerf's Avatar
Some lubes are different. For instance the new Compstar rods have a really thick lube and it is different then ARP lube. Just use oil under the washer, on top of the washer, and on the threads. Then torque to 80-85lbs
Old 08-17-2005, 08:56 PM
SDB
SDB's Avatar
we used Hylomar for the ARP bolts
SDB
Quick Reply: Torquing ARP head bolts...
