2 amps to one headunit/battery
Old 08-18-2005, 02:13 AM
volcanic2345's Avatar
Default 2 amps to one headunit/battery
how do i hook 2 amps up in one car
i have an amp for my subs now iam hooking an amp up to my inside speakers
thanks
Old 08-18-2005, 02:31 AM
transambandit's Avatar
get a distribution block, run the power from the battery to the block then get 2 shorter pieces of power cable and run it from the block to each amp. you can get a cheap block off ebay. you can eithor get one with fuses or without, though if you fused the power cable properly and you arent running over 1000w then you wont need a fused block.
Old 08-18-2005, 02:45 AM
JustAnIlluzion's Avatar
and for the headunit, if u have 2 rca outputs, just connect each amp to one of those. if u dont, just get 2 Y splitters. btw some amps can connect rcas to each other.
Old 08-18-2005, 07:14 AM
how di i connect the power to both? i have the 12v and the ground already and the rca's
Old 08-18-2005, 01:43 PM
you use a 4 gauge wire from the battery to the distribution block, then depending on what gauge your amp takes, (eithor 4 or 8) you run 2 shorter power wires from the distribution block to each amp
Old 08-19-2005, 12:42 AM
no the power from the amp to the headuint is there some kind of block i can buy for that
Old 08-19-2005, 03:05 AM
dude, go to www.fbodyaudio.com go to the tech section, it will answer all your questions, from the HU you need to find out which wire powers the amp, i think it is usually green in color for F-bodies, then you run one to the rear of your car and splice it to both of your amps. I knew jack **** about wiring stereos, i read a crap load about it and i was able to put in my entire system by myself.
Old 08-19-2005, 05:42 AM
RoadHazard's Avatar
No, you don't run power from amp to HU. The HU is powered by the harness in your car. It's the one you see after you remove the stock HU. You have to buy a new harness that matches this, and then wire it to the harness that comes with the new HU. Use this as an adapter to connect the stock harness to the new HU. The only things you connect from the HU to the amps are RCA's and remote turn-ons.
Hope that makes sense.
Old 08-19-2005, 12:46 PM
i think what he is talking about is the wire that turns the amp on and tells it when to play music.
Old 08-20-2005, 01:46 AM
thanks guys i got it ,what i was doing was adding another amp to my inside speakers so the voice can be louder i had another amp hooked to some subs but the bass was real loud and could not here the voice...so now i have 1 amp for my inside speakers and another amp for my subs...thanks guys
