View Poll Results: H/C or FI
H/C
99
63.46%
FI
57
36.54%
Voters: 156. You may not vote on this poll
Poll: Heads/Cam or Supercharger
I was told by the shop that installed my parts and tuned my car that a blower is a better way to go, more power, better driveability etc. Only costs a little more. States a blower car is wayyyyyy different than a heads/cam car. Any input would be appreciated.
Thx
Thx
It depends on how much power you want to have when it all said and done. For me it's never enough power, going in to higher hp and more boost will require a stronger bottomend = more money, Also more boost requires lower compression here comes your heads and might aswell complement them with a blower cam, see where this is going. Dont get me wrong you can put a blower on a stock moter and rum 450rwhp all day long with out any problems, and it probly will run smoother than a H/C making the same power. Figure out what your final goal for the car is going to be before you drop the $$.
SN95 Director
apples and oranges. obviously the FI will net you more power pound for pound due to better volumetric efficiency. however the entry cost to FI is steep no matter how you slice it. i say whatever you do, do it once and do it right; FI get a forged shortblock, 9.0 compression, D-1SC, full fuel system, and a FI compitant tuner.
for h/c i'd go AFR 205's, cam of choice, Fast 90/NW, fuel system (injectors/pump), and your current bot ons.
another option is cubic displacement, you can get a 402 and h/c for the price of a P1/D1. or you can look into the STS as well. there's a plethora of options, find the one that best suites your budget and application.
also, with either n/a or FI the little **** add up faster then you think..
blower cars with a stock bottem end aint maken alot more power then stock bottem end H/C cars...
FI is $$$$ lots of it... yes it can get you rediculouse hp...IF you have 5500 to sink into a shortblock 5500 to sink into the charger and pluming, 2500 to sink into labor, 800-1000 for tuning, 500-1000 for fueling .....
then you get the honor of spending at LEAST that much more to build the rest of your car to HANDLE that power...
Originally Posted by jrp
oh, and FWIW im going from a high compression forged 347 (h/c) to FI.
SN95 Director
Originally Posted by jaberwaki
you going to the dark side huh? aint many more of us N/A knights gonna be left
or STS.
i decided on the STS . i can get the power of the above combo, run pump gas, and be 100% smog legal...
my car isnt a daily driver, and is gonna be setup for HPDE's and other NASA events.
SN95 Director
oh, and other to consider is what you want your powerband to be. alot of these high power h/c setups are pushing increasingly high rpms; 6800-7200. thats great an all for the track, however on the street 2500-4500 is where you'll spend most of your time. the tq curve rules all in a daily driver. hence why FI and cubic displacement are great for daily drivers, in terms of off the throttle power. again, there are compromises to be made..
or you can have both worlds and do a boosted 402
Ya, that's what I am worried about is losing the low end......Still bugs me that the LS1's power is higher up than a 5.0....both are different cars, I know.......the LS1 makes up for it in the mid to upper, good feeling. Still difficult to break my tires lose while rolling in first gear, tried at 4000 RPM, barely let go and grabbed again.....One thing for sure is that the LS1 hooks.
hmmmm thats strange... i can break my ET drags loose on the street in 1st 2nd and 3rd..... hell 3rd from a 40mph roll
