got cam need help decifering these specs
SERIAL # Z 9060 SPEC CARD # 041520
PART # 54-000-11 LS1 CHEVY LS1/GEN III '97-UP ROLLER
CORE C54-11H LS1 1997 UP 5.7 CORVETTE 5160 SEMI Special Grind
GRIND # LS1-3715R-3715R-HR112
DURATION @ .050 INTAKE 224 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 224 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3340 EXHAUST 1.70
VALVE LIFT INTAKE .567 LOBE LIFT EXHAUST .3340
VALVE LIFT EXHAUST .567 LOBE SEPARATION 112.0
DURATION .006 INTAKE C/L 112.0
TAPPET LIFT INTAKE 277 CAM ADVANCE 0
TAPPET LIFT EXHAUST 277 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 0 JOURNAL DIAMETER
VALVE OPEN EXHAUST 44 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 44 DEPARTMENT R
VALVE CLOSED EXHAUST 0 SPC INSTR FOR CUSTOMER
i have just purchased this cam and these are the specs. i was wondering if anyone could tell me a little bit more about what if anything besides some springs to make this work. my oo ls1 has not been modified internally yet so any input would be much appreciated.
