K&N Oil Filter
Old 08-28-2005, 08:49 AM
MTCLS1's Avatar
Default K&N Oil Filter
Anyone using a K&N oil filtet? Are they worth the extra $$$$?
Old 08-28-2005, 09:06 AM
anasazi's Avatar
your going to get a lot of opinions ...
but mine is no. stay with the standard AC Delco oil filter and you'll be fine.
Old 08-28-2005, 09:08 AM
chris2000ss's Avatar
I use the K&N hp 206 on my truck and car.from what i've red there a pretty good filter
Old 08-28-2005, 09:35 AM
nostyta's Avatar
I'm using the K&N oil filter and like it alot, not for sure if it's worth the extra money, but when it comes to oil and a filter I try to use the best.
Old 08-28-2005, 12:02 PM
02NBMFormula's Avatar
yeah no complaints. i really like the nut on the bottom of the filter, that helps a ton
Old 08-28-2005, 12:14 PM
99zee's Avatar
Yep, the nut on the bottom is worth a few bucks to me.
Old 08-28-2005, 12:36 PM
SS2win's Avatar
just get the premium filter at car quest. its a dana/wix and the best u can get for the price
Old 08-28-2005, 01:31 PM
Pontiacerator
RevGTO's Avatar
LS1Tech 20 Year Member
Highly recommended. Pull one out of the box and look at how it is constructed compared to others. The extra capacity of the 2006 makes for a nice, clean 6 quart change. Wix is good and there are other good ones. I'm particular to the K&N 2006.
Old 08-28-2005, 07:36 PM
BOWTIE's Avatar
The K&N is one of the better less restrictive filters on the market, which means less oil will travel through the filters bypass with out getting filtered. On the flip side it does not filter out as small a particle as some of the others. I prefer the Amsoil filter which is slightly more restrictive than the K&N but has a finer filtering media... K&N would be my second choice. If you have some filter questions, here is a site to check out (Patman showed it to me a few years ago)... http://www.oilfilterstudy.com/
Old 08-29-2005, 05:50 AM
Patman's Avatar
The K&N is my filter of choice, it flows extremely well, is build very solid (these things are little tanks!) and I've gotten excellent oil analysis results using them. If they stopped making them, my second choice would be the Amsoil oil filter.
