Just curious....cam for 9k rpm?
Old 08-31-2005, 02:24 AM
kim307's Avatar
Default Just curious....cam for 9k rpm?
What type of cam(duration, lsa, etc) would make power/peak out around 9k rpm?
I'm just curious.....
Old 08-31-2005, 07:49 AM
crainholio's Avatar
First, give us the tech details behind the engine you're building that will spin up to 9K...what part #s and prices?
Old 08-31-2005, 07:51 AM
LOnSLO's Avatar
You have to find a cylinder head and intake that will support that first.
Old 08-31-2005, 01:20 PM
kim307's Avatar
It's just theoretical question...
I didn't think it was even possible, but I guess it is since you guys are asking for details on it.
Old 08-31-2005, 01:24 PM
Restricted User
CAT3's Avatar
My thoughts on it Solid Roller, long duration vs shorter lift, tight LSA.
Old 08-31-2005, 02:12 PM
SilverSmoke's Avatar
easy, get a rotary engine!
Old 08-31-2005, 02:13 PM
2001CamaroGuy's Avatar
and unobtanium valve train parts.....
Old 08-31-2005, 02:15 PM
Brandon Boomhauer's Avatar
since we are hear, might aswell throw some engine specs into the mix.
it would of course be solid roller.... some nasty sheetmetal intake, etc...
Old 08-31-2005, 02:18 PM
or individual runner/TB....
HUGE port heads.....
HUGE header primaries.....
TI everything.......
HUGE springs......
Old 08-31-2005, 02:38 PM
Ferocity02's Avatar
He is not building the motor... I think he is asking this question to determine what makes a cam peak when it does, at least thats what hope he wants to know.
Like he said its theoretical, not realisitc.
Old 08-31-2005, 02:51 PM
ohhhhh......so bench racing...... (j/k)
cam isn't the only thing that makes an engine peak at a given RPM.....
I always wondered what a car would be like if you could combine the launching capabilities of a full on drag car (5000HP+ big block) to get you moving with a jet car to push you the rest of the 1/4 mile......
Old 08-31-2005, 02:59 PM
Ragtop 99's Avatar
FWIW, the VTEC aftermarket cams are reverse split with 102 - 108 LSA. Different displacement, etc. but that is one way to get an idea.
Old 08-31-2005, 05:00 PM
FRISKY's Avatar
NASCAR guys build 9000-rpm small-block Chevy engines.
Old 08-31-2005, 05:05 PM
Cstraub's Avatar
correct, and use 235cc runner heads, and use 200# valve springs with flat tappets and use steel rods. It can be done as long as the wallet is there.
Old 08-31-2005, 05:13 PM
kim307's Avatar
Yeah...no way I got that much money to blow on a motor I can't even really enjoy...
With all variable in place, what kind of cam?
I think I'll need to get myself one of those Harrop ITBs to decorate my room though...looks so pretty.
Old 08-31-2005, 05:31 PM
HSV-GTS-300's Avatar
I know it's probably got a 1" stroke.....but it's still cool.
"Formula One will switch to 2.4 liter V8 engines in 2006. Cosworth has already begun dyno testing it’s V8 engine. The engine revs all the way up to 20,000rpm where the electronic rev limiter kicks in."
Click here for a video of the Cosworth V8 undergoing dyno testing.
http://paultan.org/wp-content/cosworthv8.mpg
Old 08-31-2005, 05:49 PM
BUYAMERICAN's Avatar
Renault has an F1 engine that goes to 28,000.
The stock pcm on these car does not go past 8,000 or so. So you would need a special computer.
Old 08-31-2005, 06:13 PM
redline2k's Avatar
You can't have unobtanium I believe Oakley has a patent on it.
Old 08-31-2005, 06:38 PM
Wnts2Go10O's Avatar
lets see, lightened, knife edged, billet crank, titanium rods, veerrry light pistons, some nice valve springs...understatement, titanium rockers, and well then comes ur head and cam choice... duration and lsa is wht your lookin for... actually that part depends on ur application..
Old 08-31-2005, 06:46 PM
Wow!!! Imagine how far that rod will fly when it lets loose!!!! And we all though a 7krpm blow up was bad, 20krpm!!!!!
