106 Lsa?
Old 09-02-2005, 01:01 AM
NassyVette's Avatar
Default 106 Lsa?
Whats the advantage to running such a low LSA? I listened to a clip on LS1sounds and it sounds NASTY...I like it
What do you gain/lose with a 106LSA as compared to a 112? More torque? Good for the track, bad for street? What else?
Old 09-02-2005, 01:06 AM
Casperws6's Avatar
was it the GM grand am cup cam by any chance? a blue T/A? if so that's my buddy.
just thought i'd throw that in
Old 09-02-2005, 01:36 AM
NassyVette's Avatar
The T/A was blue..not sure which cam it was...but its the only one on there with that LSA. Does his still have it...any dyno numbers etc? Sounds nice, thats for damn sure.
Old 09-02-2005, 01:55 AM
99SS-T's Avatar
I think that woudl be a very peaks cam that has very little low end. Has to sound awesome though
John
Old 09-02-2005, 10:26 AM
Casperws6's Avatar
yeah its blue with slp LTs. not sure what he dynoed, but i'll ask him and let you know
Old 09-02-2005, 02:32 PM
nuzee's Avatar
Cams with a tight lsa like a 106 will shorten the powerband but make it more intense. Usually, for street engines you'll want a wide powerband because you drive at different rpms, not only at wide open throttle. A strip engine can effectively use a shorter powerband by making appropriate drivetrain changes such as gears & torque converter.
The 106 lsa cams are popular SBC circle track cams. The circle track guys are almost always racing within a narrow powerband that can take advantage of this characteristic.
Old 09-02-2005, 03:13 PM
Sharpe's Avatar
Lower LSAs don't lower the peak power in RPMs? To clarify, I'm not asking if it lowers to peak power, I'm asking if a lower LSA makes the power peak earlier in the RPM range.
Old 09-02-2005, 03:22 PM
777's Avatar
Yes a low lsa will peak earlier in the rpm range as opposed to a high one. A 106 lsa on any decent sized cam would be a nightmare to tune I'd imagine. Not to mention the piston-valve clearance issues caused by running a lower lsa.
