HPE Dual Nozzle Stock TB Ring for sale...
Restricted User
Gets more ATTN here if the mods dont mind
Will take $100 + Shipping. I retapped the holes out so the nozzle can seat fully into the ring, they are slightly off centered from each other but I didnt drill them originally, only cleaned up the threads so the nozzles screw in like their supposed to and seat fully. If you want a single NX Shark Nozzle with the ring add an additional $25 (new nozzles are ~$55), for both nozzles total will be $150 + Shipping. I am converting to 3 stages of dry soon so no need for this.
Charlie
email for more pics, cat3n4@gmail.com
I take paypal at charles.trayer@us.army.mil
Charlie
Restricted User
Ok, throwing in 4each -3 lines (from wet nozzles to Y block), as well as 2 each NX Y fitting one blue, one red (1/8"npt to two -3 outlets), a WOT Microswitch, a -4 Main feed line for only $175.
All you'll need is a nitrous and fuel noid, relay, bottle and a -4 fuel feed. Smoking deal.
Charlie
Charlie
Restricted User
Add a fuel solenoid and you can run a dual nozzle wet shot (using two nozzle for better atomization over 200shots, and even with smaller 100 shots). Add two fuel noids and have a two stage.
I just installed a modified 5177 on my car, setup for two stages and looking at adding a third....hello HSW Edge
FWIW, I have a Dynotune LARGE nitrous solenoid I could ship with all this stuff for about $25, its only been run twice. The Fuel Solenoid is getting boxed up for return and inspection by Dean @ Dynotune.
Restricted User
Your running a dry kit now. Adding the few parts extra and you can run a wet kit, either dual nozzle single stage, or single nozzle dual stage. Basically the wet kit adds the fuel for you so you dont have to increase injector size. Both kits need tuning to perform optimally, and all that. You should be happy with your dry kit personally.
Restricted User
Updated first two posts for pics of everything included.... also change the nitrous main -4 feed line to Fuel -4 feed line. I seem to be missing on -3 x 24" fuel line, so I included ALL the NX jets I have, with pic, and NOS Powershot Fuel Solenoid in working condition. I will be sending the Dynotune Fuel noid in for repair if needed and can have it shipped to buyer upon fix.
Charlie
Charlie
