Lifter question?
Old 09-06-2005, 08:36 PM
SSDoubleK's Avatar
Default Lifter question?
What should I be looking for? Figured heads were off, screwed everything else up on cam install, was hoping I spared the lifters. Yes I'm sure I could have looked in the archives for this answer but wanted some fresh answers on this subject. Thanx.
Old 09-06-2005, 09:23 PM
c5dream's Avatar
I am in currently in the process of doing a head/cam upgrade. I am going with Morel lifters. They seem to get the best feedback but they cost around $450. My second choice would be Comp R lifters.
Old 09-07-2005, 07:22 AM
TA BOY's Avatar
If U Buy The Comp R Lifters Do U Need To Buy Adjustable Rookers?
Old 09-07-2005, 08:03 AM
PREDATOR-Z's Avatar
yes...
Old 09-07-2005, 08:07 AM
777's Avatar
I would just get some stock replacement lifters. There is no need to spend 450 when you can spend 200 and be fine.
Old 09-07-2005, 09:38 AM
PREDATOR-Z's Avatar
Agreed if it is for that 221 cam or any cam under .600 lifts.
Comp 850-16 are plenty and cheaper than OEM ones
Old 09-07-2005, 10:30 AM
LS1 Swapper's Avatar
No, I'm running Comp R's with ~0.060" preload cold with stock rockers, works just fine. Seems to be a good deal of misconception about hydraulic lifters and preload on this board. Really not sure what is up with Comp and their preload specs.
Old 09-07-2005, 10:36 AM
PREDATOR-Z's Avatar
Let us know when they fail, will you?
Comp "R" have to be .0080>.010 cold, perhaps you have 16 different length custom push rods?
Old 09-07-2005, 11:07 AM
Comp "R" have to be .080>.10 cold, perhaps you have 16 different length custom push rods?
are you running Comp R lifters?
Old 09-07-2005, 11:28 AM
PREDATOR-Z's Avatar
I've used them, yes, and they need adjustable rockers.
Unless you do not know that, lifter preload will not be equal on all of them.
With non adjustable rockers, you'll need custom p-rods of various length to achieve equality.
Comp "R" are not forgiving as other hydraulic lifters when it comes to tolerances, as a matter of fact, I would never even set preload on these cold.
Old 09-07-2005, 11:39 AM
Lasershop's Avatar
He is right. Im going through all of this now. I even tried the "Jedi suggestions" but as so far the preload has not responded........ Had to spring for adjustable rockers.
Old 09-07-2005, 11:48 AM
Tell me what is so special about these hydraulic lifters that they need a precise preload? and why would 0.040 or 0.050 or 0.060 be bad compared to 0.080-0.100?(which would be easy to achieve without adjustable rockers, but I guess they NEED them...)
What would the effect of say one preload being 0.055" and the next being 0.065"?
And why would you never set them cold?
Again misconceptions on forums
Old 09-07-2005, 11:50 AM
PREDATOR-Z's Avatar
Do you even know what lifter preload is???
Old 09-07-2005, 11:52 AM
Ben R's Avatar
I've used Comp R lifters a handfull of times with stock rockers and haven't had any problems at all.
The real question seems to be do you? Do you even understand how a hydraulic lifter works?
Old 09-07-2005, 11:55 AM
PREDATOR-Z's Avatar
You seem to know, please teach me
Old 09-07-2005, 12:03 PM
That's what I thought.
Old 09-07-2005, 12:05 PM
Lasershop's Avatar
According to Comp... R series lifter preload is .003 to .005. I would imagine it takes some serious time to achieve that kind of tolerance. I suppose the motor might actually run with the valves hanging open 50, 60 eighty thou' or so........
Not trying to pick a fight, but when I decided on Comp "R's" I also had to complete the package to support them.
Old 09-07-2005, 12:08 PM
Which is why I said earlier about not being sure what is up with Comp and their preload specs.
It's not going to hang your valve open unless you bottom out the lifter with too much preload, the spring in the lifter is no match for the valve spring.
Old 09-07-2005, 12:13 PM
PREDATOR-Z's Avatar
I edited my post as i noticed I made a typo on preload setting it is .008>.010 cold.
.060 preload is way too much and the lifter will collapse if set that much upon pump up.
from a reputable sponsor builder.
The R's want .002-.004 preload at operating temps. Because the aluminum block and heads expand more under heat than the steel lifters and pushrods, hot preload will be less than cold preload by about .006 to .008. So if you set cold preload less than about .010, you run the risk of hot preload going to zero, which will cause lots of problems including plenty of valve noise and eventual failure.
If you do not believe this, then call someone who builds LSx and uses them frequently.
