Lifter question?
Comp 850-16 are plenty and cheaper than OEM ones
Comp "R" have to be .0080>.010 cold, perhaps you have 16 different length custom push rods?
Unless you do not know that, lifter preload will not be equal on all of them.
With non adjustable rockers, you'll need custom p-rods of various length to achieve equality.
Comp "R" are not forgiving as other hydraulic lifters when it comes to tolerances, as a matter of fact, I would never even set preload on these cold.
What would the effect of say one preload being 0.055" and the next being 0.065"?
And why would you never set them cold?
Again misconceptions on forums
Not trying to pick a fight, but when I decided on Comp "R's" I also had to complete the package to support them.
It's not going to hang your valve open unless you bottom out the lifter with too much preload, the spring in the lifter is no match for the valve spring.
The R's want .002-.004 preload at operating temps. Because the aluminum block and heads expand more under heat than the steel lifters and pushrods, hot preload will be less than cold preload by about .006 to .008. So if you set cold preload less than about .010, you run the risk of hot preload going to zero, which will cause lots of problems including plenty of valve noise and eventual failure.
