Where to get all parts for a Procharger set up?
Is there anyone that sales the 8 rib, front mount IC, pipes, blower, fuel pump, injectors as a full kit?
From what I have found is either the Twin Flow, which I have heard restrict flow. Or they come with the 6 rib, which cause slippage. Dont want to buy the kit if I am going to use half the parts.. Seems dumb. So, does anyone make the full kit? Know what I mean?
I would like to go new.. Thanks
Originally Posted by slow
while I don't know if either makes a full kit, I would give both SD Concepts a call, as well as Synergy motorsports.
Ryan
Ryan
I understand what you want to do, buy a complete kit with the upgraded parts already included, right? I don't know of any companies that do that. What you might want to do is buy the head unit, used is preferrable. Then go to SDCE for the bracket, mounting hardware, and 8-rib kit. Then go to Synergy for the front mount intercooler and all of the piping. They can probably hook you up with the bypass valve too to fit on their kit. Then you can find some used 42# injectors and pump on here. You will also need to do something with your fans. You can go to ATI for the fan shroud then get a 16" Spal fan from Summit. Or I think you can go with some dual Flex-a-lite fans in front of the A/C condensor. Someone did that on here and apparently they fit perfectly without modification. I can find the thread for you if your interested. That will give you a complete kit.
Now I didn't say no one makes something like this. I am sure someone does, but I don't know who. Synergy might be able to do this. Maybe A&A Corvette(not sure if they do F-body work). I'd look through the sponsors and make some phone calls. Maybe make a post in the sponsor specials sale section.
Call me at 260 483-9300 and I can give you a quote on the kit. You will also need an ATI Performance Products harmonic balancer, which is sold by the ATI harmonics balancer company that is a totally different company. This balancer is required to work with the eight rib kit. I sell the balancer as well as the fuel injectors and fuel pump that is required to complete the kit. The only thing left that you will need is tuning. Bob
