should I buy the TnT power ring
Old 09-08-2005, 09:36 PM
slick red z's Avatar
Default should I buy the TnT power ring
I got the chance to buy the tnt kit brand new for 800.00 with warmer and purge. I have herd that it can be difficult to install,that is the power ring. Also I'm not familiar with tnt products should I go ahead and buy it
Old 09-08-2005, 10:57 PM
Gregg 00SS's Avatar
TNT makes very good kits. I bought the power ring seperately as I already had a nitrous kit and wanted to clean things up a little bit with either a maf kit or power ring. I had no problems installing the power ring, haven't used it yet, but it's installed.
Old 09-08-2005, 10:58 PM
Matt@HSW's Avatar
It's a good kit. The install can be a little diffucult, but it isn't that bad. Take your time with it and you'll be fine.
Matt
Old 09-09-2005, 06:23 AM
GM Muscle's Avatar
I'd go ahead and buy it. You may have to trim your lid alittle but it's not to bad. It's a good quality kit for sure.
Old 09-09-2005, 07:48 AM
XTrooper's Avatar
If you have the room for the power ring, it's a nice piece. I didn't.
Old 09-09-2005, 08:33 AM
Z'mnypit's Avatar
I had to trim my lid a bit, but once all was installed you cant beat that look. Its a real nice clean piece.
Old 09-09-2005, 09:24 AM
Nitro Dave's Nitrous Outlet's Avatar
Its a good system with quality parts.It may require a little work to get it to fit right.What brand heater and purge?
Dave
Old 09-09-2005, 09:32 AM
TNTramair's Avatar
TNT now sells a lid and coupler to go with its power ring i believe...you might want to check with them...makes the installs a snap. goodluck..BTW..i have it and love it so far.
Old 09-09-2005, 09:47 AM
2001 Red Coupe Bandit's Avatar
I bought a Seperate TNT power ring to go with my NX Kit for my 2001 C% Corvvette.
X-Trooper, what do you mean YOURS didn't go on???? What problems did you have?
I knwo they fit Vettes because I have seen them on before?
Just curious
Old 09-09-2005, 02:22 PM
XTrooper's Avatar
Just curious
The space between my Halltech carbon fiber air bridge and throttle body is a pretty short distance. It would just have been too tight of a fit for the ring. The silicone pieces would have been barely wide enough to accomodate the hose clamps, so I decided against it.
Now that Nitro Dave has announced that he's coming out with his own N2O plate, I'm going to go with one of them. It's working fine as it is, but I'm just not crazy about having my nozzle mounted in the silicone hose coupling.
Old 09-09-2005, 05:38 PM
I got mine from Dave, it was an older TNT unit, but still fine. I hope it works, if not I am sure he will let me send it back from a credit toward his nos plate.
I think it will work as my installer specifically told me he liked the tnt ring and that is the only reason I bought one.
Thanks Trooper.
I am trying to determine bottle locations now. The trunk is fine, but I have such a pretty aluminum bottle holder I hate to hide it.
Old 09-10-2005, 11:32 AM
thanks everyone , hope my install comes out good
