What happend to RR's turbo cars?
8 second mod
just wondering, i havent heard anything about his old shop car or the formular he did, any of them still around?
Originally Posted by TchargedLS1TA
I missed out what happened to the whole RR & QMP.. Can any elaborate the details or isnt something that isnt talked about?
steve ill tell about it..in pm
no nee dto bring up a dead horse
LS1Tech Co-Founder
I now own RR's silver Formula. A local guy bought it and changed it to a heads/cam/nitrous car, and I picked it up off of him about 3 months ago.
The car has been completely gutted down to the shell, and basically everything has been replaced. I call it "Project Censored" for obvious reasons
Here is what it had done at Madman Racing:
Wolfe 10-point chrome moly cage (certified for 7.50 ET or slower)
cam-lock harnesses installed (both seats)
window net installed
Wolfe thru-floor subframe connectors
Billingsley fab 9" rearend w/ anti-roll bar (35-spline, gun drilled axles)
BMR torque arm, LCA's, panhard
BMR k-member with upper and lower A's
QA1 coil overs
Aerospace front brakes
Strange rear brakes
New brake lines and braided lines
Custom tranny x-member
TCI Dedenbear cased Powerglide installed
TCI torque converter (stalled for 900-1000 rwhp @ 3000 lbs)
TCI Outlaw shifter
TCI trans-brake
TCI tranny cooler
Thunder Racing line-lock kit
Billingsley ABS delete block
Madman manual front steering rack
Madman heater delete firewall plate
A/C system completely removed (including inside dash)
catback system removed
Power steering pump removed
airbags removed
ARP lug studs pressed into front hubs
Up next:
408ci iron block is being built by LME (9.0:1)
AFR 225 heads
Custom twin-turbo setup (twin 60mm) using 6.0L manifolds
Install Weld Aluma-Star wheels and tires (billet fronts)
Revise the interior with lightweight carpet and new seat covers.
Pics:
https://ls1tech.com/98Formula/DSC00697.JPG
https://ls1tech.com/98Formula/DSC00698.JPG
https://ls1tech.com/98Formula/DSC00699.JPG
https://ls1tech.com/98Formula/DSC00700.JPG
https://ls1tech.com/98Formula/DSC00701.JPG
https://ls1tech.com/98Formula/DSC00702.JPG
https://ls1tech.com/98Formula/DSC00703.JPG
https://ls1tech.com/98Formula/DSC00704.JPG
https://ls1tech.com/98Formula/DSC00705.JPG
https://ls1tech.com/98Formula/DSC00706.JPG
https://ls1tech.com/98Formula/DSC00707.JPG
https://ls1tech.com/98Formula/DSC00708.JPG
https://ls1tech.com/98Formula/DSC00709.JPG
https://ls1tech.com/98Formula/DSC00710.JPG
https://ls1tech.com/98Formula/DSC00711.JPG
https://ls1tech.com/98Formula/DSC00712.JPG
https://ls1tech.com/98Formula/DSC00713.JPG
QA1 coil overs
Strange rear brakes
TCI Outlaw shifter
TCI trans-brake
TCI tranny cooler
airbags removed
Up next:
AFR 225 heads
Pics:
NKAWTG...N
The QMP silver camaro is in located in a northern chicago burb by me. It hasn't been driven in a long time to my knowledge. Ask 97M6Formula about it if you really need to know, his buddy owns it. I haven't seen the car in about 2 years.
QA1 coil overs
Strange rear brakes
TCI Outlaw shifter
TCI trans-brake
TCI tranny cooler
airbags removed
Up next:
AFR 225 heads
QA1 coil overs
Strange rear brakes
TCI Outlaw shifter
TCI trans-brake
TCI tranny cooler
airbags removed
Up next:
AFR 225 heads
Were they just a standardized connector used for the mustangs as well, or were they model specific for the 4th gens?
Originally Posted by Mike 01WS6
I haven't seen anyone do thru-floor subframe connectors yet on the 4th gen. I was curious about doing it a few years back. Looks good.
Originally Posted by 2QuickZ's
My old LT1 convertible had through the floor subframe connectors. They were custom made chromoly pieces. The guy that put my roll bar in did them and they worked out awesome! I never got pictures of it with the carpet out of the car, though.
Any pics of it underneath? The vert floor pan is quite a bit different than Tony's formula and was curious of what was cut out to fit them. (I have a vert)
