Apexi safc
In the back of the manual, there are several car models listed, and a corresponding value for one of the settings. None of them are a gm maf type car. I tried several different values for that setting, and never could get the pcm to recognize the altered maf value.
A mini-afc might work for you. zzperformance is the only place I know of that has it.
We've tried on an LT1/LS1 MAF and they did not work. The signal an LS1 MAF sends out is different than what a SAFC can correct. However, it will work if you want to hook it up to a MAP sensor. Don't know how that would work for tuning though
