What should air fuel ratios be when spraying.
Old 09-14-2005, 04:32 PM
Raced Guy's Avatar
Default What should air fuel ratios be when spraying.
I have a 99 C5 air filter and exhaust and was wondering what my afr's should be when spraying a 100 or 150 shot on a wet kit.
Old 09-14-2005, 05:08 PM
Matt@HSW's Avatar
It varies; it's really up to you. The richer you are (up to a point) the safer you are, but the richer you go the less power you'll make. I would not go much leaner then 12.2 ish and not much richer then high 10s on that size shot.
Matt
Old 09-14-2005, 05:32 PM
GM Muscle's Avatar
I like to run mine on the safe side. 11.0 to 11.5.
Old 09-14-2005, 08:37 PM
Airwolf's Avatar
Anything under 12.0 should be safe. I would rather leave a few ponies on the table then lay the $$$ on it!
Old 09-14-2005, 10:43 PM
Elite_Hot_Rod's Avatar
Same here, makes good power and still on the safe side.
Old 09-14-2005, 11:16 PM
Raced Guy's Avatar
Cool thanks for the help.
Old 09-15-2005, 02:25 AM
Robert56's Avatar
11.5 to 11.7 depending on where at in my curve.
Robert
