Anyone in Austin Texas Area
Anyone local to Austin. I could sure use some help installing the Moser 12-bolt, Plenty of beer any pizza can be provided. I will do most of the install, just could use someone with experience on the install for some assistance.
Thanks
Scott
Thanks
Scott
TT-TECH Veteran
Im working all weekend. Then monday I pull my motor
Jeff
Originally Posted by Inspector12
Liar! you are not going to pull that motor cause your scared of speed. LOL! Call me if you need any phone support. Good luck with an uneventfull motor pull. That 12 bolt is an easy swap you don't even have to take the brake lines loose 30-45 minute swap. T/A, DS, Shocks, Swaybar, PHB, LCA's springs Calipers and ABS. If you were in the area I'd supervise the whole swap. I am good at that I do that to the guys at G-force all the time I think it drives them crazy LOL! Good luck and Have fun.
Jeff
Jeff
Im at UT, I installed my 9" with the help of a friend lifting it into place so I could help you with stuff like that. It should be a pretty easy swap, just have to align everything. are the axle ends ready to go as far as brackets and stuff?
send me a PM if you need me to help out
TT-TECH Veteran
Considering I pulled two of them in two days I say Im on a role LOL. Were you serious on the pistons? I think it will be fine. Not the best for FI but it will work and hold
Jeff
Oh yeah I was serious I did it to my friend Jaysons cost $160 for all 8. It is done all the time JM. You will be fine with the 6.0 heads. I am sure it will hold up! Call me later if you get a chance.
Jeff
Jeff
Yeah that is what I have basicly. Sounds good won't be long now unless you change your mind on your setup alot like my friend Jason has done a lot of Ha Ha! I ready to see some number from your car should be good.
