In car 12 volt switched power
my 01 Z has no power options, windows, locks etc...I hooked the wire for the arming switch up and it blew the 10A gauge fuse, what wire can I use for the 12 v to the arming switch?
I would check your wiring on the switch it a relay should take less than 1 amp to trigger. If it is a lighted switch it sounds like the ground and output wire are switched.
I went outside waiting for a reply and hooked it to the Radio?ACCY wire on the back side of the fuse panel. No problem, found out I had the wires on the inside switch hooked up wrong and was blowing the inline fuse on the main relay wire. Well, now I have power on the orange main wire to the relay, but no power coming out of the relay, I guess I cooked it???
Under your steering wheel there's a panel with your trunk release switch (if you have that switch). There are two phillips screws and two 9/32" (or 7mm maybe) hex screws... remove them, pull out the panel, and pick any of the 30 pink wires to tap into.
-somebody
-somebody
I dont have trunk release, we did finally get this thing working, very nice. Feels good, 1st gear is def useless even at 20 or so roll, I have some Nittos to put on but am now afraid of breaking the rearend
