In car 12 volt switched power
Old Sep 16, 2005 | 04:19 PM
89ws6formula50's Avatar
Default In car 12 volt switched power
my 01 Z has no power options, windows, locks etc...I hooked the wire for the arming switch up and it blew the 10A gauge fuse, what wire can I use for the 12 v to the arming switch?
Old Sep 16, 2005 | 04:28 PM
SSDriver's Avatar
I use the the PINK wire from the ASR switch in the center console. From what I understand any solid PINK wire in our cars is switched 12volts. Hope this helps.
-William
Old Sep 16, 2005 | 04:29 PM
smokeum99ta's Avatar
Try the fuse panel.I know theres one thier because thats how I wired mine.
Old Sep 16, 2005 | 04:35 PM
kenSS's Avatar
i hooked my shift light up to the pink wire behind the asr switch in the dash
Old Sep 16, 2005 | 04:37 PM
redline2k's Avatar
The large pink wire from the key switch is the main ignoition for the car. You can also grab the ignition behind the radio it should be a yellow wire next to the orange.
I would check your wiring on the switch it a relay should take less than 1 amp to trigger. If it is a lighted switch it sounds like the ground and output wire are switched.
Old Sep 16, 2005 | 05:54 PM
I went outside waiting for a reply and hooked it to the Radio?ACCY wire on the back side of the fuse panel. No problem, found out I had the wires on the inside switch hooked up wrong and was blowing the inline fuse on the main relay wire. Well, now I have power on the orange main wire to the relay, but no power coming out of the relay, I guess I cooked it???
Old Sep 16, 2005 | 09:30 PM
Somebody09's Avatar
Under your steering wheel there's a panel with your trunk release switch (if you have that switch). There are two phillips screws and two 9/32" (or 7mm maybe) hex screws... remove them, pull out the panel, and pick any of the 30 pink wires to tap into.
-somebody
Old Sep 17, 2005 | 02:18 AM
I dont have trunk release, we did finally get this thing working, very nice. Feels good, 1st gear is def useless even at 20 or so roll, I have some Nittos to put on but am now afraid of breaking the rearend
