Recomendations On NX Amount ?
Have car listed in sig. Wnated some recomendations on a safe amount of spray to run on car without worrying to much about damaging anything. i am going to get a good nx kit. preferably one that is tps controlled with maf. Was thinking maybe 50 shot 75 ? Just that edge i mught need just in case.
You'll get very mixed opinions on this subject. I lurk around with a 50 shot on my 408ci and i can DEFINITELY feel it.
a 50 or 75 shot on your setup (with proper fuel system) will be a lot of fun.
Originally Posted by Elite_Hot_Rod
I'd say 100 shot minimum other wise it won't be worth it.
Stock fuel pump yes. I really just want to make sure that I won't be in danger of damaging anything. Just want that extra push. If I go with 100 shot will it be safe? my thinking with the 50 is that I can use it with no worries. Which would be nice.
My goal is saftey. I really just don't want to over do it. I am going to rebuild the bottom end xmas 2006' so i figure untill then I would like to have something in case. Just don't want to kill it. Emphasis on safe without damage.
With your h/c package and a 100 shot, your stock fuel pump might not keep up. But with a fuel pump, good kit, and maybe a touch up to the tune, a 100 shot should be perfectly safe with your set up.
With a 75 shot, you'll be fine. That what I was spraying since I installed my kit and what I ran the times in my signature with. I very recently bumped it up to a 100 shot, but my fuel pump was running out of steam. I just installed a Lingenfelter upgraded fuel pump in it last night, but haven't gotten to test the system with it yet.
P.S.- Don't bother with a 50 shot. If you're going to spray at all, do at least a 75.
Well, for those of us that do bother with a 50 shot... sometimes it's all you can spray since you're on stock tires
That will change next weekend though
At the same time I plan on getting bigger injectors and a new tune. The current tune I have is for my last cam. Not the one in my sig. So as of right now New tune Bigger injectors 75 shot will be more than safe. I plan on getting the best nx kit I can for under a grand. Thanks for all the help. This is why I love this site.
