Recomendations On NX Amount ?
Old Sep 25, 2005 | 11:51 AM
khris99s's Avatar
Default Recomendations On NX Amount ?
Have car listed in sig. Wnated some recomendations on a safe amount of spray to run on car without worrying to much about damaging anything. i am going to get a good nx kit. preferably one that is tps controlled with maf. Was thinking maybe 50 shot 75 ? Just that edge i mught need just in case.
Old Sep 25, 2005 | 12:04 PM
SiL3NtXWS6's Avatar
You'll get very mixed opinions on this subject. I lurk around with a 50 shot on my 408ci and i can DEFINITELY feel it.
a 50 or 75 shot on your setup (with proper fuel system) will be a lot of fun.
Old Sep 25, 2005 | 12:10 PM
Elite_Hot_Rod's Avatar
I'd say 100 shot minimum other wise it won't be worth it.
Old Sep 25, 2005 | 12:17 PM
GM Muscle's Avatar
I agree, it's not worth it for a super small shot. I would say 75 bare minimium. Are you still running a stock fuel pump?
Old Sep 25, 2005 | 01:06 PM
khris99s's Avatar
Stock fuel pump yes. I really just want to make sure that I won't be in danger of damaging anything. Just want that extra push. If I go with 100 shot will it be safe? my thinking with the 50 is that I can use it with no worries. Which would be nice.
Old Sep 25, 2005 | 01:09 PM
khris99s's Avatar
My goal is saftey. I really just don't want to over do it. I am going to rebuild the bottom end xmas 2006' so i figure untill then I would like to have something in case. Just don't want to kill it. Emphasis on safe without damage.
Old Sep 25, 2005 | 01:21 PM
GM Muscle's Avatar
With your h/c package and a 100 shot, your stock fuel pump might not keep up. But with a fuel pump, good kit, and maybe a touch up to the tune, a 100 shot should be perfectly safe with your set up.
Old Sep 25, 2005 | 01:38 PM
XTrooper's Avatar
With a 75 shot, you'll be fine. That what I was spraying since I installed my kit and what I ran the times in my signature with. I very recently bumped it up to a 100 shot, but my fuel pump was running out of steam. I just installed a Lingenfelter upgraded fuel pump in it last night, but haven't gotten to test the system with it yet.
P.S.- Don't bother with a 50 shot. If you're going to spray at all, do at least a 75.
Old Sep 25, 2005 | 01:43 PM
SiL3NtXWS6's Avatar
Well, for those of us that do bother with a 50 shot... sometimes it's all you can spray since you're on stock tires
That will change next weekend though
Old Sep 25, 2005 | 01:52 PM
XTrooper's Avatar
Well, stock tires can handicap almost any mod. Luckily, however, this problem can be easily rectified.
Old Sep 25, 2005 | 01:55 PM
khris99s's Avatar
At the same time I plan on getting bigger injectors and a new tune. The current tune I have is for my last cam. Not the one in my sig. So as of right now New tune Bigger injectors 75 shot will be more than safe. I plan on getting the best nx kit I can for under a grand. Thanks for all the help. This is why I love this site.
Old Sep 25, 2005 | 02:04 PM
XTrooper's Avatar
Is this a dry or wet kit you're planning on? As you probably know, when using a wet kit, the injectors aren't a factor in fuel delivery, so the bigger injectors wouldn't be necessary unless you're getting them for future mods.
