Are the front O2s the only ones that affect gas mileage?
Ive learned these cars have 4 o2 sensors, but if I think o2s are the reason for horrible gas mileage, shouldnt i only worry about the front 2? Ive already ordered a k&n and will soon be replacing the fuel filter as well.
Bad 02 sensors
What kind of rear end gear do you have and how many miles do you have also? I have a 98 z with 87,000 miles and a 3.73 rear gear and also have 2 bad sensors but they are by the cats.Also what kind of gas mileage are you getting do you have a A4 or M6?
the rear o2's have nothing to do with your fuel mixture, they simply activate an ses code for emissions upon removal or malfunction. The front o2's are the ones responsible for adjustments in the fuel curve. But, they are generally not the cause of bad gas mileage. You might want to clean your maf, that can often help to make your car run more efficiently. buy some electronics SPRAY ON cleaner, dont brush it!
