Oil P/U tube O-ring
Old 09-28-2005, 02:34 PM
ashade98's Avatar
Default Oil P/U tube O-ring
I found 2 part #'s LS-1: #12557075 and LS-6: #12557752.
I have a 98 LS-1 and I'm going to use a ported LS-6 oil pump from TSP. Which part # do I need??????
Thanks
Old 09-28-2005, 04:32 PM
LS1FIRE's Avatar
Thanks
I was in this same situation when i installed my oil pump on my 98 recently. I used the new ls6 one its thicker then the ls1 one but it seems to be just a tad bit looser the ls1 one. The old one felt more tighter. Luckly i repalced it I ended up doing the install once with the old Seal and found a new one and decided to do it again. I inspected the old seal very carfully and there seem to be a small cut in the old seal so it was a good thing i changed it out.
Old 09-28-2005, 04:47 PM
ashade98's Avatar
So the ls6 one???
Anybody else??
Old 09-28-2005, 04:50 PM
LS1FIRE's Avatar
I used the ls6 one without any problems here is the link to the thread i started asking the same question. https://ls1tech.com/forums/showthrea...2&page=1&pp=20
