Who has used ARP head BOLTS?
Old 10-02-2005, 09:23 AM
ashade98's Avatar
Default Who has used ARP head BOLTS?
Like the title says, any Problems??
Old 10-02-2005, 09:33 AM
blacktransam's Avatar
nope i loved mine
Old 10-02-2005, 01:04 PM
ashade98's Avatar
That's it??? C'mon, I know guys/gals are using these.
Old 10-02-2005, 01:28 PM
00Formula's Avatar
Just put them on my friends turbo car. Seem to do really well.
Old 10-02-2005, 09:18 PM
Dixit's Avatar
I used them on my Z06 and had a problem where all the bottom most bolts where almost 1 thread too long. We called up ARP and they said this is a known issue in some GM LS1/LS6 blocks and they actually sell a tool that taps the threads to the correct depth. But they said if we dont want to do that, we can safely grind off 1 thread off without damaging the integrity of the tensile strength.
This was a problem when we installed AFR heads on the LS6 block with stock .054 GM MLS head gasket. So this is not a problem on ALL blocks, just certain ones, seemed like GM quality control wasnt the best on that area.
Obviously if I got studs wouldve never seen or known the problem.
Dixit
Old 10-02-2005, 09:32 PM
ArcticZ28's Avatar
Used 12 point studs on my old engine. Nothing but great.
Old 10-03-2005, 12:56 AM
BOONE's Avatar
Great product, ive had no issues.
Old 10-03-2005, 01:03 AM
Jimmy P's Avatar
Just get the studs..
Old 10-03-2005, 01:39 AM
pkincy's Avatar
None
Perry
Old 10-03-2005, 08:38 AM
ashade98's Avatar
Thanks for the input, I'm not asking about STUDS though! I already have the ARP head bolts. I'm trying to get opinions on the head BOLTS! Thanks
Old 10-03-2005, 09:06 AM
Dixit's Avatar
Just do the method we did. Put in the head bolts. If during your final torque sequence or even earlier you feel the torque wrench feels springy, then you've bottomed out that bolt. Just remove it and grind off just 1 thread. Then reinsert it and torque it down to spec.
Dixit
Old 10-03-2005, 03:29 PM
ashade98's Avatar
Anyone else??? I know you guys are runnin' these!
TTT
Old 10-03-2005, 04:50 PM
SLowETz's Avatar
Studs. No install probs. No issues. The ONLY way to go IMO. ***** bolts.
Old 10-03-2005, 04:54 PM
superchannelkev's Avatar
no problems with bolts
Old 10-03-2005, 05:04 PM
Brandon Boomhauer's Avatar
bolts here too.
no problems.
Old 10-03-2005, 05:09 PM
mr2guru's Avatar
Bolts here with unmilled heads and GM MLS gaskets...no problems.
Old 10-03-2005, 07:06 PM
IN DEBT's Avatar
No problems here.
Old 10-03-2005, 09:17 PM
cowboysfan's Avatar
do ARP bolts need retq'd after x amount of milage? dont want to hijack here. I think since we are on subject of these type's of bolt I would ask Q.
fuerzaws6
Old 10-03-2005, 09:33 PM
mr2guru's Avatar
fuerzaws6
I'd retorque about 2hrs after initial install. Then retorque after first heat cycle.
Old 10-07-2005, 10:18 PM
cowboysfan's Avatar
do factory stock hardware require same tq requirements?
fuerzaws6
