Can you build a 427 w/out sleeving?
Originally Posted by OUTLAWZ RACING
I did took a brand new slp 402 short block keept it a secret and sold the rotating assembly and had it punch out and bam 427 i paid 300 out the pocket because of the differance in price for pistons and stuff
There is a translation.
Originally Posted by Wet 1
You cant take an ls2 block 120 over... nore a iron block
aint happening.
sonic testing on the iron for 60 over... so i've heard
Was it a sleeved block to begine with ?
Some of you guys are just .... well.... talking nonsense.
Sonic test on an iron block is mandatory for .060 bore. You could go through a dozen before you find one that passes.
.080 is stupid unless you have 2 more in the trailer for the final passes. Those that use them are super max effort, track only setups.
Either sleeve or C5R, that is what is on the market right now.
There is a glimmer of hope for the future. The 6.2l is 4.065 bore stock in a aluminum block so it won't go much bigger (Maybe .020). The block will be produced in iron with a 4.065 base bore, this may produce the ability for a 4.120 final on the right block. Not sure when this block will be released in iron, but 08 model year should be safe bet.
Kurt
Kurt
