What Bottle Jacket/blanket for Florida?
Old 10-06-2005, 09:52 AM
FLC6's Avatar
Default What Bottle Jacket/blanket for Florida?
I have a C6 and need a Bottle jacket/blanket.
The NX one for a 15lb bottle is $132!!!!
Is that considered the best one? The NOS one is only $52.
Is the NX one more insulated?
Anyone else have a recommendation? My bottle is in the sun all the time. I do have tinted windows but it doesn’t work well.
Old 10-06-2005, 11:21 AM
next's Avatar
The pressure build up from Florida heat is going to be hard to stop even with a blanket. I found I can't leave a bottle in the car if it's parked outside during the day in the summer heat. Last time I did that it pegged over 1600 psi.
I'm suggesting this because I think you'll spend money on a blanket and it won't help. Yes it will stop the direct sunlight, but your car will still be +130* inside.
Just my .02.
Old 10-06-2005, 11:29 AM
Nitro Dave's Nitrous Outlet's Avatar
The difference between the NX and others on the market are night and day.......
The NX is like a thick Quilt compared to a then sheet.......
When I first seen how much the NX ones were I did not understand why they were so high untill I got one...
As far as the sun being the problem.If its a 100 degress in the car so is everything in the car.Nothing can be done about that.However keeping the directsun off of it will help.
Dave
Old 10-06-2005, 12:27 PM
gollum's Avatar
The Black NX bottle jacket works best at retaining bottle heat in winter time and covering up that ugly bottle heater.
Attached Thumbnails What Bottle Jacket/blanket for Florida?-026_23.jpg
Old 10-06-2005, 01:09 PM
Robert56's Avatar
The NX wraps all the way around, whereas most all the others hang with an open bottom. Fire and Ice heater cooler might be something to think about. It will keep bottle within 5psi of set pressure. Might be good for a day at the track, but not for every day cause of constant batt drain. It is a low power consumer, so leaving it on for a hour or two at the track between charges shouldn't be a problem.
Robert
Old 10-06-2005, 06:51 PM
1999TransamWs6's Avatar
I agree in florida heat the blanket is no help i have one and it will still peg 1600 on a hot day while im at work.
Old 10-06-2005, 08:40 PM
black01_WS6's Avatar
dam thats good to know about florida as im putting on a dry shot and havent thought about the heat for when i move down to florida.
Old 10-06-2005, 08:45 PM
NitrousDirect's Avatar
We offer a thick double quilted blanket for $29
And yes heat in florida is very hard to combat
Old 10-06-2005, 09:15 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
The NX jacket is built from ballistic Nylon.. It will completely incase the bottle. The jacket is roughly 3/4 + thick. I can do a pressure drop test or rise test to show just how good it is.. The only area that it does not cover is the valve...
And your pricing is way more than any of dealers would sale that to you.. The cost has to do with the materail, the thickness, and just how many layers of material there is.. Just becuase its looks thick does not mean it will do anything for the bottle in the heat or cold.
Ricky
Old 10-06-2005, 09:30 PM
Dustin's Avatar
Originally Posted by NitrousDirect
LOL we offer a thick double quilted blanket for $29
Where is it at on the webpage?? Also CFN told me they wouldnt have one out for about 3 weeks? I am confused here...
Old 10-06-2005, 10:12 PM
Not sure where you heard that? BUT! We have them in stock and ready to go
Here ya go
http://nitrousdirect.com/bottleblankets.html
Old 10-06-2005, 10:17 PM
Dustin's Avatar
Here ya go
Actually if you are "open" I would like to order the winter special with the heater and blanket. pm me the number!
Old 10-06-2005, 10:34 PM
pm sent
Old 10-06-2005, 10:35 PM
Robert56's Avatar
Another way for you guys to get your bottle temp down in a hurry when rising out of your control, is: just flip the bottle upside down and open the valve, you will feel the coolness moving down the bottle. This works much better than just bleeding extra pressure off. You wont waste as much nitrous. Try it, you'll like it. By the way, I do have a Nitrous Direct bottle blanket and they are nice, a very good value.
Robert
Old 10-06-2005, 10:41 PM
Dustin's Avatar
Robert
Good tip, and glad you like the blanket cuz i am ordering one right now.
Quick Reply: What Bottle Jacket/blanket for Florida?
