Cleaning O2 sims
Old 10-14-2005, 12:35 AM
s.o.m.SS's Avatar
Default Cleaning O2 sims
whats the best way to clean an o2 sim? thanks...
Old 10-14-2005, 12:52 AM
ninobrn99's Avatar
die electric cleaner, non residue.
Old 10-14-2005, 08:46 AM
s.o.m.SS's Avatar
any one agree or disagree?
Old 10-14-2005, 08:48 AM
TAQuickness's Avatar
agree
but then again, does it matter what i think?
Old 10-14-2005, 09:08 AM
ninobrn99's Avatar
you would dare to doubt me?!?!
Old 10-14-2005, 11:01 AM
I1ULUZ's Avatar
Why was the sim inside your engine, this is the INTERNAL ENGINE forum right? Shouldn' they be outside the engine so they don't get dirty with oil?
Old 10-14-2005, 11:48 AM
DramaFoYoMama's Avatar
He means the O2 sensor. He's throwing all the codes for the driverside front. I suggested he try cleaning it before buying one as it might just have carbon deposits all over it that can be cleaned off.
Old 10-14-2005, 11:52 AM
just replace it. it won't hurt
Old 10-14-2005, 01:35 PM
I1ULUZ's Avatar
1. Make sure the wires are not grounded/melted
2. Make sure the sim is on the rear O2 plug not the FRONT O2
Sounds more like sim is on the wrong plug, he couldn't even figure out the correct name of the part to clean or the correct forum to post the question in. Sounds like he needs hands on supervision.
Old 10-14-2005, 02:21 PM
GuitsBoy's Avatar
If you do indeed mean your o2 sensor, then you can try urning off the deposits with a propane torch. Put the sensor in a vice and heat it till its cherry red for a few seconds on each side. After I was getting insufficient switching codes, this would buy me an extra week or two before the codes came back.
Old 10-14-2005, 02:38 PM
s.o.m.SS's Avatar
well thanks for the help and to ******** i apologize for my ignorance
Old 10-14-2005, 05:09 PM
ninobrn99's Avatar
dont worry about it man...its how we learn. if its the o2 sensors, do not go cheap! get the gm ones!! also, try to find the source of the problem...maybe it just went bad, maybe the sim is connected wrong...double check everything..
Old 10-14-2005, 06:16 PM
s.o.m.SS's Avatar
o2 sensors are new, but we scanned my car and the driver side is throwing every o2 code... what should i do?
Old 10-14-2005, 06:43 PM
ninobrn99's Avatar
whats the code?
Old 10-15-2005, 09:58 AM
I'd have to scan it again. I know it had insufficeint switching and heater performance. I told him how he could fix those. I get the light on every single time if I don't set the closed loop below 125 degrees on the coolant temp. My exhaust doesn't heat up very quickly. I think it was also throwing high and low voltage.
Old 10-15-2005, 10:52 AM
98UltraZ's Avatar
Since the sensors are new, are they Bosch by any chance?!?! If so, take them back... From my experience over half of them fail shortly after install.. I will NEVER buy another Bosch 02 ever again for the f-body..
Old 10-15-2005, 10:56 AM
98UltraZ's Avatar
That is the typical code shown with the Bosch 02 sensors.. Like I said in the other post, if they are bosch.. take them back..
