Help Please Question bout buying cams
Old 10-17-2005, 02:47 AM
blackdrag on's Avatar
Default Help Please Question bout buying cams
when buying a new cam do i have to buy the complete kit, valves, springs, rods or what is it that i need to be set? thanks
Old 10-17-2005, 03:06 AM
FUN LS1's Avatar
You definitely want to replace the springs and push rods. You'll also need the seal/gasket kits for the timing cover, water pump, and valve covers, plus the crank bolt. Most places you get the cam will offer a kit for $50 or so...
You may want to add new valve stem seals and titanium retainers, or need new seats, depending the springs you choose.
Old 10-17-2005, 03:11 PM
Your choice of TSP camshaft, Manley valve springs good to .600" lift, Manley titanium retainers, Texas Speed & Performance hardened pushrods $639.99
Basic Camshaft Bolt & Gasket Kit Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets, GM Harmonic Balancer Bolt $43.99 '
with this will i be set or what else do you think i need?
