Northwest Members WA, OR, ID, MT, WY, SD, ND
Finally finished my dyno tune (yes, I'm lazy...)
Old 10-18-2005, 09:15 PM
Silverhawk_02TA's Avatar
Default Finally finished my dyno tune (yes, I'm lazy...)
I finally got off my *** and got the car on the dyno so I could finish my tune. I picked up about 14 hp and 12 ft-lbs peak over my previous best run. I also pickup up about 20 ft-lbs at 3K rpm. Mods are as follows:
TSP Lid, Torquer V.1 cam, PRC dual spring kit, Pacesetter LT's, TSP true duals, and a home ported TB. Still no underdrive pulley. Here's the graph:
Strangely enough, my torque curve did not improve at all when I fattened the AFR up to 12.5, or even 11. It didn't change at all. It seemed to like 26* of timing up until torque peak for the best torque curve, and then 28* from there on for best horsepower. Guess it's time for some heads now...
Oh, and those numbers uncorrected are 332 HP and 312 TQ way up here in Albuquerque! I miss sea level...
Old 10-18-2005, 11:30 PM
sardog46's Avatar
Hey man nice nummbers, glad you finnaly got it figured out.
Old 10-19-2005, 05:24 AM
00Vette's Avatar
Those are nice............That's more than I put down on the Dynojet with H/C. And you don't even have a cam..........
Old 10-19-2005, 01:11 PM
My1st Truck's Avatar
Can't wait to get mine, Ellis is going to do it. I have Mac Mid lengths that will go on in NOV.
Nice Numbers! Are those all of your mods? A4 or M6?
Old 10-19-2005, 01:46 PM
WS6freak's Avatar
What?? You have H/C and are putting less than 400? Something is wrong. Call the groo master!!
Old 10-19-2005, 06:15 PM
Yep, that's it. Through an M6. It took so long because I fried the Z06 clutch I had in there. And I babied that thing %90 of the time, too. The last time I dyno'd before changing the clutch out to a Spec 3 my numbers were really low (like 370/340 SAE or something like that) because the clutch wouldn't hold on the dyno. Here's what it looked like when I pulled it out:
That was the first and last time I'll remove and replace my tranny without the benefit of a lift and a transmission jack. Catching a T-56 falling off of a floor jack in the chest is not fun...
Old 10-19-2005, 07:05 PM
Racehead's Avatar
That looks a little too lean to me ? I'd be a little concerned about going over 13 at WOT myself. Can't argue with your numbers though. Just don't go open road racing with it like that
Old 10-19-2005, 07:32 PM
Yep, I thought so too. I fattened it up first to 12.5:1 and then 11.0:1, and the torque curve didn't budge, which seemed kinda strange. Horsepower took a hit though. I didn't get any knock retard at 13.5:1, so I wasn't too concerned about the leanness of the run. However I did set the AFR to 12.5:1 up to the torque peak, and leaned it out to 13:1 after that. I pulled pretty much the same numbers, but for some reason I can't find a log file of that run.
Old 10-19-2005, 09:07 PM
00Vette's Avatar
Yeah............I don't have headers either. But I figure with the headers I would still only hit just at 400whp! When I get it back I plan on dyno tuning it. Hopefully Ellis will help me see more than 400whp
Old 10-19-2005, 10:31 PM
tjwong's Avatar
If he dyno'd in ABQ he is at 5000 feet above sea level. That in itself will take a big bite out of his power curve. I lived in Grants NM for almost 10 years. That place is a 6500 feet! I rode a 550cc KTM 2 stroke dirt bike there for all those years, we would hill climb MT. Taylor which peaks at 11300 feet, let me tell you that 550 felt like a anemic 250 at that altitude, but it would still blow away a CR500 Honda. I ran a blown 396 LT4 in my 95 C4 there, and I never had to use the Crane Boost retard, I ran 12 PSI of boost there and it never rattled once. I sure miss New Mexico, great people, nice country to play in, never had to deal with damn SEED EATERS there.
Old 10-19-2005, 11:30 PM
Compstall's Avatar
I'll take the seed eaters thanks....
deeeeee-de-deeee-deeeee...."This just in....New Mexico, #50 in the U.S. for Education....."
Quick Reply: Finally finished my dyno tune (yes, I'm lazy...)
