timing
timing
are any of you guys using a digital 6 to pull timing when the nitrous is engaged? I was thinking of running a digital 6 for timing and a msd digital window switch so i dont spray through the gear shift.....is there any thing else i can use besides those two things? TIA
Originally Posted by Robert56
If your stock and stock timing, 150 hit is still no worry. I would still log and check for KR if it were mine.
Robert
Robert
im gonna put the timing to stock or try to get something to control my timing while im on the bottle (maybe a digital 6) but right now the car isnt stock. it has heads and cam, ls6 intake, ported TB, pacesetter LT's, etc.
LS1 Timing Tuner sounds like it would fit the bill. It'll allow you to run full timing off the juice and pull it when you spray. It also has a window switch. Here's a link for more info:
http://www.harrisspeedworks.com/shop...age=1&featured
Matt
Matt
