Purge was Clear, was I blowing Just Air???
Finally got my bottle empty. However, the last 6 or 7 times I was purging over several days, NO WHITE Plume was visible. It was just Air comming out, or at least I didn't see any white cloud, the pressure was 550 since I was just hitting the bottle opener OPEN, then purging right after that.
I wonder if I got a bunch of air when I got it filled. I was told sometimes if you get the bottom of the barrell, you get Air and not Nitrous???
Thanks Robert, and go to bed, it's late! I will tell you how the nitrous works, when I can actually use the darn stuff. I am breakign in an engine and purged away peerfectly good nitrous.
Hopefully trhe end result will be worth it. My car feels faster now with the new engine and reworked heads. I am almost scared to spray the nitrous
Thanks
Thanks
I always say break em in like your going to use em. Now I would of made sure everything was ok and seated the rings first. (maybe a week) then spray the $hit out of it but hey thats just me.
Originally Posted by 2001 Red Coupe Bandit
I have about 150 miles on her so far. Hopefully the rings are seated good
need to complete my install to put on blow down tube and also the noid for the bottle heater and the bottlee needs to be empty for this, so I just want to get it finished and there wasn't but 1/3 of it left, they used it testing it and for 2 or 3 dyno runs before the #7 piston that was dammaged finally gave out
