Purge was Clear, was I blowing Just Air???
Old 10-21-2005, 01:21 AM
2001 Red Coupe Bandit's Avatar
Default Purge was Clear, was I blowing Just Air???
Finally got my bottle empty. However, the last 6 or 7 times I was purging over several days, NO WHITE Plume was visible. It was just Air comming out, or at least I didn't see any white cloud, the pressure was 550 since I was just hitting the bottle opener OPEN, then purging right after that.
I wonder if I got a bunch of air when I got it filled. I was told sometimes if you get the bottom of the barrell, you get Air and not Nitrous???
Old 10-21-2005, 01:51 AM
Robert56's Avatar
Yea, when you get to the lower pressures you won't see much, but it still is nitrous, just take a whiff, you'll know for sure if you got burned (sulfur smell). Also, pure air won't be cold.
Robert
Old 10-21-2005, 01:56 AM
Thanks Robert, and go to bed, it's late! I will tell you how the nitrous works, when I can actually use the darn stuff. I am breakign in an engine and purged away peerfectly good nitrous.
Hopefully trhe end result will be worth it. My car feels faster now with the new engine and reworked heads. I am almost scared to spray the nitrous
Thanks
Old 10-21-2005, 02:03 AM
Robert56's Avatar
I bet it does feel more powerfull, just break it in the way it makes you comfortable. Then spray away, that's what it was built for. Good luck.
Robert
Old 10-21-2005, 02:32 AM
02SilverWS6's Avatar
Thumbs up
Originally Posted by 2001 Red Coupe Bandit
...I am almost scared to spray the nitrous
Thanks
Noooo, don't say that. Just do it.
Old 10-21-2005, 03:08 PM
I just Paid $5K for a new engine, THATS Why I am scared to spray , not because I am scared to spray
Old 10-21-2005, 05:59 PM
n2ojunkie's Avatar
I always say break em in like your going to use em. Now I would of made sure everything was ok and seated the rings first. (maybe a week) then spray the $hit out of it but hey thats just me.
Old 10-21-2005, 07:00 PM
I have about 150 miles on her so far. Hopefully the rings are seated good
Old 10-21-2005, 07:54 PM
00Vette's Avatar
I had my motor fully rebuilt back in 03 and had to stop and go drive it for 500miles before I could really get into her. You got to seat those rings. I broke my motor in with dinosaur oil, then when I hit 500miles I switched over to fully synthetic (which is what I was using before the rebuild).
TS6
TS6's Avatar
Why did you waste the nitrous? Just close the valve and use it when you're ready.
Old 10-23-2005, 01:58 AM
need to complete my install to put on blow down tube and also the noid for the bottle heater and the bottlee needs to be empty for this, so I just want to get it finished and there wasn't but 1/3 of it left, they used it testing it and for 2 or 3 dyno runs before the #7 piston that was dammaged finally gave out
Old 10-23-2005, 02:42 AM
slowpoke96z28's Avatar
did the bottle not already have a blowoff valve? i'm not getting having to empty the bottle to put a blowdown tube on.
Quick Reply: Purge was Clear, was I blowing Just Air???
