LS6 Lightweight Valve Wear Issue???
Old 10-22-2005, 04:34 PM
vettenuts's Avatar
Default LS6 Lightweight Valve Wear Issue???
Someone has alerted me to an issue with pre- mature wear on the top of the valve stem, which is why GM got away from them. Has anyone got any knowledge of this issue or experience? I was looking hard at a pair of LS6 heads because of the lightweight valves and this news sort of takes the wind out of the sails
Old 10-22-2005, 06:15 PM
redtail2426's Avatar
yeah i read something a while ago ablout something being screwy with the lightweight valves,cant remember but i think it was something about the hollow valves creating a resonance problem.The ls7 uses sodium filled exhaust valves,but solid titanium for the intake valve,so it probably has something to do with the intake valves.
Old 10-23-2005, 12:00 AM
rhubar's Avatar
I don't think that's true. lsx valvetrains use roller-rocker arms and hyd. lifters adjusters, all these componets make valvetrain wear extreamly minimal.
Old 10-23-2005, 10:10 AM
mrr23's Avatar
the stock rocker arms do not have roller tips on them. only roller trunions. so, you still get the scrubbing that's associated with the non-roller tipped rockers on the tips of the valves.
Old 10-23-2005, 11:33 AM
vettenuts's Avatar
I am wondering if it is an issue with the locks. Does anyone know if the locks are on solid material, or hollow? This is the first I have heard of this, but the second time it was mentioned to me by a separate source that there were issues with these valves.
Old 10-23-2005, 12:03 PM
RPO_Z06's Avatar
From what I understand reading about this issue is unless your beating on it every second of its life (ie full race duty) the wear factor is negligible.
Old 10-23-2005, 06:18 PM
vettenuts's Avatar
Did you find an article or something?
