Tips on cutting SS hose
Old 10-29-2005, 08:04 AM
7 Second Club
Phil99vette's Avatar
Default Tips on cutting SS hose
Does anyone have any tips on how to cut SS hose to keep the SS braided cover cut clean.
Phil
Old 10-29-2005, 08:13 AM
stevemilz's Avatar
I wrap it with electrical tape and use a cut off wheel (dremel works good also).
Old 10-29-2005, 08:14 AM
TN_TRITON's Avatar
Wrap the hose in masking tape where you are cutting. Then cut through the tape and it will help the braid to cut cleaner without fraying.
Old 10-29-2005, 08:36 AM
7 Second Club
I tried using a chop saw and it seemed to fray it pretty good on the bottom side. I guess I will try a grinder with a thin cutoff wheel.
Phil
Old 10-29-2005, 08:41 AM
Jake the SSnake's Avatar
This is what I do(dremel). I think I read in one of my car mags to take a sharp chisel and give it a whack with a hammer haven't tried it yet though.
Old 10-29-2005, 10:24 AM
BAKED's Avatar
I've heard of that too.
Old 10-29-2005, 11:29 AM
hotrodrx7's Avatar
The shop where I get my braided hose wraps it with reinforced tape then cuts it with bolt cutters.
Old 10-29-2005, 01:08 PM
Wet 1's Avatar
Same here.
Old 10-29-2005, 08:33 PM
mattr228's Avatar
you should use a 32 teeth/ inch hacksaw blade when cutting it .. wrap it in masking tape and cut it in the middle of the tape
Old 10-29-2005, 10:59 PM
Richiec77's Avatar
DO the cold chisle and it'll work Great. You'll want to grind roughly a 45 deg bevel on the chisel. You'll also need some Aluminum to do it too. I saw that in a Mag and gave it a shot. Works great.
Old 10-30-2005, 01:24 AM
racecar's Avatar
Wrap tight with silver duct tape and use an air powered thin cut off wheel. You can cut without one frayed wire.
Old 10-30-2005, 03:34 AM
tbojbob's Avatar
Whack it w/a cold chisel on a piece of 1/4" (minimum) thick aluminum (6" x 6" will do). Make sure the chisel has a good edge on it.
Old 10-30-2005, 06:15 AM
baldurann's Avatar
I'd say use a cutoff wheel on a dremel, or something to that effect.
Old 10-30-2005, 09:08 AM
7 Second Club
I used a cutoff wheel in a grinder, 3m masking take and worked awesome. Some grease ont he fittings and they slid right togther. I was really amazed at how easy they went together.
Phil
Old 10-30-2005, 10:21 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
from my experience this seems to leave the cleanest cut
Old 10-30-2005, 12:46 PM
hondo's Avatar
i wrap it tightly in that strapping tape, i also put TWO 32 tpi blades in my hacksaw going in opposite directions. i havent tried the chisel method but i'll have to test it
Old 10-30-2005, 01:40 PM
NOBR8KSS's Avatar
Ditto on the cold chisel and block of aluminum...leaves no chance of fraying and is much quicker. Make sure to put a knife edge on the chisel first.
Old 10-30-2005, 03:28 PM
Blown408's Avatar
Can you cut -6 and -8 this way as well?
